Phobya Adapter 3Pin (12V) to 3Pin (7V) - Black 20cm
- Article no.: LK
- EAN: 4049469099855
- Weight: 0,007 kg
Sleeve:
Length: 20mm
Color: black
Special features: Reduces the voltage from regular 12 volts to 7 volts
Connection type: 3 pin standard
1x Phobya adapter 3Pin (12V) to 3Pin (7V) 20cm - Black
Tech Review
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
