Phobya Y-Adapter 4Pin Molex to 4x 3Pin (12V) - Black 30cm
- Article no.: LK
- EAN: 4049469100513
- Weight: 0,023 kg
A Y-cable from a 4-pin Molex connector to 4x 3-pin (12V).
For connecting up to 4 fans to a 3-pin connector (CPU cooler, case fan, etc.) to a power supply connector (4-pin Molex). The trick here is that the 4-pin Molex connector is looped through. This means you don't lose any Molex connectors on your power supply and don't have to split them any further!
A white sticker on the cable indicates which one transmits the speedometer signal.
Sleeve:
Sets:
Technical details:
Connectors: 4 pin Molex to 4x 3 pin (12V)
Color: black sleeves, black connectors, black shrink tubing
Dimensions: complete 30cm
RoHS compliant
1x Phobya Y-Adapter 4Pin Molex to 4x 3Pin (12V) 30cm - Black
1. Seite: | 1x 4Pin |
Bauform: | Y-Kabel |
Sleeving: | schwarz |
2. Seite: | 4x 3Pin |
Hersteller: | Phobya |
