  • 18549
  • 4250197185493
  • 1,1 kg
Content: 1000 Milliliter
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
€19.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Red 1m (3.3ft) Retailbox 100cm
€7.98*
€16.98*
WZS filling aid - plastic funnel
€4.99*
With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and... more
Notes
It is essential to avoid adding other biocides or anti-corrosion fluids, as well as diluting the fluid with distilled water, otherwise the basic and coordinated properties of the fluid will be lost.
UV inkNot UV active
Content1000ml
SpecificationReady mix
Colorred
ManufacturerAlphacool
Delivery date: in 7 - 8 weeks
€36.98 *
€28.98 *
€10.98 *
€1.78 *
Delivery date: in 9 - 10 days
€3.98 *
€20.98 *
€5.99 *
€6.49 * €8.98 *
