Phobya Y-cable 3Pin Molex to 9x 3Pin Molex - Black 60cm
- Article no.: LK
- EAN: 4049469078089
- Weight: 0,043 kg
For connecting nine 3-pin fans (radiator fans, case fans, etc.) to the mainboard connector (3-pin). Please note that when using the cable, speed monitoring is only possible for one of the connected fans.
A white sticker on the cable indicates which one transmits the speedometer signal.
Sleeve:
Sets:
Technical details:
Connectors: 3 pin to 9x 3 pin Y-cable
Colour: black sleeve, black connectors, black shrink tube
Dimensions: 60cm
RoHS compliant
1x Phobya Y-cable 3Pin Molex to 9x 3Pin Molex 60cm - Black
Note: When using this distributor, please pay attention to the requirements of the slot, on the mainboard or the fan controller. Excessive loads, pay attention to the wattage of the fans, can lead to damage.
This product was tested for you:
Aqua info
Tech Review
2. Seite: | 9x 3Pin |
Bauform: | Y-Kabel |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
