Alphacool NexXxoS ST30 Full Copper X-Flow 480mm radiator
- Article no.: 14231
- EAN: 4250197142311
- Weight: 1,169 kg
*1The new Alphacool NexXxos radiators, a name that stands for experience and quality has come to bring a fresh breeze to the radiator market.
Following this tradition, the new NexXxos radiators are the first to truly deserve the “Full copper” attribute. All main parts, not only the fins and channels, but the chambers are also made from copper. This brings an improvement in performance where other radiators are left without a chance. In structure, the Alphacool NexXxoS X-Flow Radiators differentiate materially from the standard radiators. The X.Flow Radiators are designet for high flow rates. The bevelled copper chambers on both sides have an identical structure. This Water is jetting at the same time through all avialable channels to the other chamber to whitch it then leaves the radiator.
Versatile and easy mounting is one of the main points, on which the research and development department at Alphacool focused. The chamber offers three possibilities for fitting installation on both inlet and outlet (not on the NexXos ST30). Less angled fittings are needed, improving flow rates and offering more mounting possibilities.
Here, too, Alphacool provides the popular sizes of the 120mm series. Different thicknesses, 30mm, 45mm and 60 mm underscore the broad spectrum that cover these radiators.
Even mounting and installation of fans and radiator grills is easy and versatile with these radiators: The M3 threads are standard in the radiator sector and available in all lengths at an affordable price.
| Technical data | |
| Dimensions (L x W x H) | 532 x 124 x 30mm |
| Quantity of cooling channels | 12 |
| Cooling channels | Copper |
| Color | black |
| Connection | 4x G1/4" |
| Fan thread | M3 |
| Slats | Copper |
| Thickness | 39 - 49mm |
| Fan size | 120mm |
| Housing | Steel |
| Pressure tested | 0,8 bar |
| Manufacturer | Alphacool |
| Fins per inch | 16 |
| Number of fans | 4 |
