Alphacool Apex PCI-e 4.0 Riser cable - 20cm
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
  • 17636
  • 4250197176361
  • 0,15 kg
€59.98 * €74.98 * (20.01% Saved)
Content: 20 Zentimeter (€299.90 * / 100 Zentimeter)
€62.98*
11951 Alphacool Aurora vertical GPU mount with riser cable
€79.98*
13548 Alphacool Eisblock Aurora Acryl RX 7900XT Reference with Backplate
€99.98*
The 20cm long Alphacool Apex PCI-e 4.0 riser cable enables flexible and individual positioning... more
The 20cm long Alphacool Apex PCI-e 4.0 riser cable enables flexible and individual positioning of the PCI-Express x16 slot inside or outside the case.
Flexible application!
Should the graphics card be changed regularly, the riser cable helps to spare the PCI-Express slot of the mainboard. Therefore the cable is very suitable for testbenches and causes no performance loss within the 4th PCI-e specification. Due to the 20cm cable length, plenty of available space for PCI-e expansion cards is available, which greatly increases the mounting options.
Suitable for modding!
The high quality Apex PCI-e 4.0 riser cable from Alphacool also scores in modding projects. Due to its six cable strands, a high flexibility and durability is guaranteed. Thus, for example, the graphics card can be mounted upright. In addition, the cable is very suitable for SSF cases due to its length.
Cable typeconnection cable
Connector 1 (internal)PCIe (16x) Plug
Connector 2 (internal)PCIe (16x) Socket
Length PCI riser cable200 mm
Compatibility PCI riser cablePCIe 3.0 x16, PCIe 4.0 x16
Connector angledno
Cable sleevedno
Cable colourblack
Connector colourblack
€5.99 *
€1.48 *
Delivery date: in 12 - 13 weeks
SZ Schlauchabschneider
hose cutter
€6.29 *
€4.48 *
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
€26.98 *
