Phobya Y-Adapter 4Pin Molex to 2x 4Pin PWM and 3Pin - Black 30cm
- Article no.: LK
- EAN: 4049469136185
- Weight: 0,019 kg
A Y-cable from a 4-pin Molex connector to 1x 3-pin and 2x 4-pin (PWM) (12V).
For connecting up to 3 fans to 1x 3-pin and 2x 4-pin (PWM) connectors (CPU cooler, case fan, etc.) to power supply connectors (4-pin Molex). The trick here is that the 4-pin Molex connector is looped through. This means you don't lose any Molex connectors on your power supply and don't have to split them any further!
Sleeve:
Sets:
Technical details:
Connectors: 4 pin Molex to 1x 3 pin and 2x 4 pin (PWM) (12V)
Color: black sleeves, black connectors, black shrink tubing
Dimensions: complete 30cm
RoHS compliant
1x Phobya Y-Adapter 4Pin Molex to 2x 4Pin PWM and 3Pin 30cm - Black
Aqua info
Tech Review
1. Seite: | 1x 4Pin |
Bauform: | Y-Kabel |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 3x 3Pin |
