Alphacool Core XP³ Brass
- Article no.: 13059
- EAN: 4250197130592
- Weight: 0,76 kg
With the Alphacool Core XP³ Brass you get a very compact CPU water block for all current mainstream sockets from AMD and Intel. It offers the typical high Alphacool quality paired with excellent performance at a fantastic price.
High cooling capacity!
The cooling plate has been optimised to give the best performance for the price point. The nickel-plated copper radiator bottom has a surface area of 56 x 56 mm with a cross-slot structure and only 0.4 x 1 mm thick pins through which the water can flow. Due to the extremely large cooling surface, the water can effectively absorb the heat from the radiator bottom and remove it from the CPU area. The pin area is about 27.6 x 37.6 mm ensuring that most mainstream CPUs are covered completely which guarantees high cooling performance. The new multiple slotted nozzle plate was developed especially for this cooler to achieve a perfect interplay of water flow and inflow of the base plate. Only the combination of all these little things ensures the high performance.
Quick assembly!
The mounting bracket is simply put over the CPU cooler. All mounting screws can be pre-assembled onto this Then you can simply screw it down. A well-illustrated manual with large render graphics is included so that the installation is easy to understand.
Intel: 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066
AMD: AM5 / AM4 / AM3+ / AM3 / AM2
Technical data | |
L x W x H | 73 x 63 x 21mm |
Weigth | 310g |
Material cooling plate | nickel plated copper |
Material cooler top | Acetal |
Connections | 2 x G1/4" |
Material Deckel: | Messing |
Anschluss: | 2xG1/4 |
Sockel: | AMD AM3/AM3(+)/AM2/AM2(+)/939/FM2/FM1/G34/940;AMD AM5 ;AMD AM4 ;Intel 115x ;Intel 2011(-3) ;Intel 2066 ;Intel LGA 1200 ;Intel LGA 1700 ; |
Abmessungen (L x B x H: | 63 x 73 x 21mm |
Liefertermin: in 2 - 3 Wochen
