Alphacool Eisblock XPX Pro 1U Ampere LGA 4926
- Article no.: 13529
- EAN: 4250197135290
- Weight: 0,52 kg
*1The Alphacool Eisblock XPX Pro 1U Ampere LGA 4926 is a reliable CPU water cooler that offers outstanding cooling performance.
Optimized for Ampere LGA 4926
This Alphacool Eisblock XPX Pro is specifically designed for the Ampere LGA 4926 socket, making it exclusively compatible with this socket variant. The flow rate has been optimized to be able to reliably dissipate the waste heat.
Versatile Connectivity Options
Thanks to its three inlets and five G1/4 outlets, the Eisblock XPX Pro allows for flexible connections in almost any direction. It is designed to be ideal for all 1U cases, providing all the versatility needed in a server or workstation system.
Ampere: LGA 4926
| Technical data | |
| Dimensions (L x W x H) | 79,00 x 63,68 x 27,20 mm |
| Material cooling plate | nickel plated copper |
| Material cooler top | Nylon |
| Weigth | 230g |
| Pressure tested | 0,8 Bar |
| Connections | 3 x G1/4" (IN) | 5x G1/4" (OUT) |
| Color | black |
