Alphacool Eisbaer Extreme liquid cooler core 280 - black edition
  • 11608
  • 4250197116084
  • 2,651 kg
  • Currently there are 5 available
€187.98 * €199.98 * (6% Saved)
€6.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - Chrome
€6.98*
ANS Alphacool Eiszapfen 13mm HardTube screw-on nozzle G1/4 - Deep Black
€6.98*
ANS Alphacool Eiszapfen 13mm HardTube screw-on nozzle G1/4 - Chrome
€6.98*
12565 Alphacool Eisblock XPX CPU - deep black
€39.98*
Revolutionise your system with the Eisbaer Extreme Core, the foundation of your new watercooled... more
Revolutionise your system with the Eisbaer Extreme Core, the foundation of your new watercooled PC. We believe that the Alphacool EIsbaer Extreme Core Radiator with pump is stronger, more beautiful and quieter than anything you've ever known in water cooling.
Pure Performance
The Eisbaer Extreme is a brand-new design for Alphacool. A high-quality housing encloses the radiator and fans as well as a patented pump/reservoir combination. With the Eisbaer Extreme you have the coolest cooling for your hardware.
Progress into a New Age
Alphacool gives you the flexibility you need. Use your Eisbaer Extreme perfectly thanks to the new Eisbaer Ready quick-release couplings. These are compatible with all Eiswolf / Eisbaer quick release connections. The powerful VPP Apex pump gives you the flow you need.
Individual
With the Eisbaer Extreme you decide how your system is structured. You can expand this All-in-One at any time with additional components, modify it or fill it according to your desires. Whether you install the Eisbaer Extreme horizontally or vertically, it's up to you how you showcase your water cooling system.
Technical data (general)
Dimensions (LxWxH)385.5 x 156 x 64 mm
Housing materialaluminium
Reservoirintegrated, 138 ml
Maintenance optionsFillport with patented screw plug
Technical data Alphacool VPP Apex Pump
ControlPWM
Connection4-Pin PWM | SATA
Maximum head pressure4.25 m
Rotational speed2500-4500 rpm
Technical data Alphacool Core 140mm
Dimensions140 x 140 x 25 mm
Operating VoltageDC 7-14 V
Control Range0-2000 rpm ±10 %
Max. Air Flow103.03 CFM
Max. Static Pressure2.81 mmH₂O
Noise level38.3 (Max: 40.0) dBA
Bearing Typehydraulic Bearing
Life Expectance50 000 h at 25 °C
Connector4-Pin PWM
Speed Control Modevia PWM
€39.98 *
€57.98 *
€2.48 *
WAC Alphacool Core 1 Silver
52%
Hint!
€4.80 * €9.98 *
€27.98 *
€28.98 *
