Alphacool Eisbaer Extreme liquid cooler core 280 - black edition
- Article no.: 11608
- EAN: 4250197116084
- Weight: 2,651 kg
Revolutionise your system with the Eisbaer Extreme Core, the foundation of your new watercooled PC. We believe that the Alphacool EIsbaer Extreme Core Radiator with pump is stronger, more beautiful and quieter than anything you've ever known in water cooling.
Pure Performance
The Eisbaer Extreme is a brand-new design for Alphacool. A high-quality housing encloses the radiator and fans as well as a patented pump/reservoir combination. With the Eisbaer Extreme you have the coolest cooling for your hardware.
Progress into a New Age
Alphacool gives you the flexibility you need. Use your Eisbaer Extreme perfectly thanks to the new Eisbaer Ready quick-release couplings. These are compatible with all Eiswolf / Eisbaer quick release connections. The powerful VPP Apex pump gives you the flow you need.
Individual
With the Eisbaer Extreme you decide how your system is structured. You can expand this All-in-One at any time with additional components, modify it or fill it according to your desires. Whether you install the Eisbaer Extreme horizontally or vertically, it's up to you how you showcase your water cooling system.
| Technical data (general) | |
| Dimensions (LxWxH) | 385.5 x 156 x 64 mm |
| Housing material | aluminium |
| Reservoir | integrated, 138 ml |
| Maintenance options | Fillport with patented screw plug |
| Technical data Alphacool VPP Apex Pump | |
| Control | PWM |
| Connection | 4-Pin PWM | SATA |
| Maximum head pressure | 4.25 m |
| Rotational speed | 2500-4500 rpm |
| Technical data Alphacool Core 140mm | |
| Dimensions | 140 x 140 x 25 mm |
| Operating Voltage | DC 7-14 V |
| Control Range | 0-2000 rpm ±10 % |
| Max. Air Flow | 103.03 CFM |
| Max. Static Pressure | 2.81 mmH₂O |
| Noise level | 38.3 (Max: 40.0) dBA |
| Bearing Type | hydraulic Bearing |
| Life Expectance | 50 000 h at 25 °C |
| Connector | 4-Pin PWM |
| Speed Control Mode | via PWM |
| Color | black |
