Phobya 4Pin PWM to 8x 4Pin Splitter
- Article no.: LZ
- EAN: 4049469174064
- Weight: 0,054 kg
With this PWM splitter from Phobya, it is possible to supply up to 8 PWM fans with power at the same time and also to transmit the PWM signal from the first fan to all 8 fans. This makes sense for large radiators, for example.
The splitter is very compact and can be easily installed in the housing. The adhesive tape on the back allows the circuit board to be attached anywhere in the housing, but it can also be attached using two screws in the holes on the outside.
1x circuit board
1x adapter cable
1. Seite: | 1x 4Pin, 1x 4Pin PWM |
Bauform: | Y-Kabel |
Hersteller: | Phobya |
2. Seite: | 8x 4Pin PWM |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/fe/95/9f/1011111_1aIOZNK7lZCfVK_200x200..jpg)
![S13 Alphacool EPDM Tube 13/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/6c/ae/02/1021502_01_200x200..jpg)
![ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - 6pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/c8/29/f0/1022497_1gAlejgQeBmAEv_200x200..jpg)
![KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/5c/61/96/1013984_101DDl0D3Lrcrs_200x200..jpg)
![ANS Alphacool Eiszapfen 13mm HardTube Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/87/3f/0d/1012836_1_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
