Alphacool VPP Apex Pump - G1/4 inner thread including Eisdecke D5 - Acetal V.3
- Article no.: 13305
- EAN: 4250197133050
- Weight: 0,777 kg
The Alphacool VPP Apex pump including the Eisdecke D5 Acetal V.3 combines powerful PWM-controlled pump technology with a versatile pump top. Three inlets, two outlets, and a stable mounting base allow for flexible integration into any custom loop system.
With the Eisdecke D5 Acetal V.3, the Apex VPP pump receives a housing that impresses both functionally and visually. The Eisdecke offers maximum flexibility in tube routing with a total of three inlets and two outlets. The new bracket ensures a stable stand and also allows installation in a 3.5" drive bay.
The Apex VPP is based on the well-known D5 format but has been significantly improved in key areas. Instead of a spherical bearing, it uses a ceramic shaft, which increases smooth operation and significantly reduces vibrations. Thanks to the redesigned coil layout, power consumption has been nearly halved.
Power is supplied via a modern SATA connector. The 4-pin PWM connector allows precise control and monitoring of the pump’s speed – ideal for users who demand full control over their system.
Optionally, the pump unit can be expanded into a complete pump/reservoir combo by adding a separately available reservoir top – perfect for compact and high-performance water cooling setups.
| Technical data: Apex VPP Pump | |
| Dimensions (L x W x H) | 65 x 65 x 41mm |
| Material pump | synthetic material |
| Material pump cover | aluminium |
| Material axle | ceramics |
| Connections | 4-Pin PWM | SATA |
| Rotational speed | 2500 - 4500 RPM |
| Cable lengths | 4-Pin PWM - 48cm | SATA - 48cm |
| Operating voltage | 8-13V DC / 14W IP32 |
| Starting voltage | 12V DC |
| Maximum pumping head | 4,25m |
| Maximum flow rate | 340L/h |
| Weight | 276g |
| Color | black |
| Technical data: Eisdecke D5 - Acetal V.3 | |
| Dimensions (L x W x H) | 80 x 80 x 40mm |
| Dimensions (L x W x H) with stand | 83 x 80 x 87mm |
| Material | Acetal |
| Threads | 5x 1/4" |
Warranty: 5 years
