Phobya extension 3Pin Molex extra long - Black 60cm
- Article no.: LK
- EAN: 4049469077921
- Weight: 0,008 kg
Extension cable for connecting 3-pin fans (CPU cooler, case fan, etc.) to the motherboard connector or other fan connector (3-pin Molex), approx. 60 cm long. Includes speedometer signal forwarding.
A white sticker on the cable indicates which one transmits the speedometer signal.
Sleeve:
Sets:
Technical details:
Connectors: 3 pin extension
Color: black sleeve, black connector, black shrink tube
Dimensions: 60cm
RoHS compliant
1x Phobya extension 3Pin Molex 60cm - Black
Aqua info
Tech Review
2. Seite: | 1x 3Pin |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
Bauform: | Verlängerung |
