Phobya 4Pin PWM Male to Male - Black 60cm
- Article no.: LK
- EAN: 4049469206680
- Weight: 0,013 kg
Cable is covered with black sleeving and has black connectors.
Technical data:
- 1. Side: 4 pin PWM connector
- 2nd side: 4 pin connector
- length: 60cm
1x Phobya 4Pin PWM male to male 60cm - Black
1. Seite: | 1x 4Pin PWM |
Bauform: | Adapter |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin PWM |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/eb/d7/3d/1012290_1tlvQkhD7AzAfN_200x200..jpg)
![ZK Phobya 2pin-Kabel Verlängerung Buchse/Stecker 60cm - Schwarz](https://aquatuning.shop-cdn.com/media/image/c7/f9/cf/82395_1htpdMgr639sYa_200x200..jpg)
![WAK Alphacool Eisblock Aurora Geforce RTX 4090 GameRock + Phantom mit Backplate](https://aquatuning.shop-cdn.com/media/image/c0/78/8e/1023376_1qIyach7RIC9x4_200x200..jpg)
![S16 Alphacool EPDM Tube 16/10 - Black 3m (9,84ft) Retailbox](https://aquatuning.shop-cdn.com/media/image/ff/71/84/1021503_1Bs1yo9o5BbZhJ_200x200..jpg)
![ANK Alphacool Eiszapfen Schnellverschluss Stecker G1/4 AG - Deep Black](https://aquatuning.shop-cdn.com/media/image/1f/c9/34/1015607_1_200x200..jpg)
Liefertermin: in 5 - 6 Tagen
![KAB Alphacool Powerbutton/Taster Verbindungskabel - Schwarz 200cm](https://aquatuning.shop-cdn.com/media/image/fc/fa/be/1013971_1Two7nB1ZuCA6l_200x200..jpg)
![ANS Alphacool Eiszapfen 16/10mm Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/c8/13/36/1011163_1d5LginqNaeo4y_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/7f/40/da/81092_1MzMueJ4xNN7xz_200x200..jpg)
![LK Phobya Verlängerung 3Pin Molex extra lang - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/78/1c/07/81033_1ipZON9lFQDWAz_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 60cm weiß](https://aquatuning.shop-cdn.com/media/image/e2/01/79/1023499_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 60cm weiß](https://aquatuning.shop-cdn.com/media/image/0a/1e/67/1023496_01_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 4x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/a1/78/b1/1023149_01_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 3x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/de/82/fa/1023143_01MutHfHA1rB0Ju_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 2x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/b6/14/a2/1023143_01_200x200..jpg)
![KAB Alphacool Verlängerung JST aRGB 3-Pin auf 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/cc/76/5c/1023136_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 60cm](https://aquatuning.shop-cdn.com/media/image/c4/00/a0/1023114_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 60cm](https://aquatuning.shop-cdn.com/media/image/de/5a/97/1023111_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 2x 4-Pin PWM 15cm](https://aquatuning.shop-cdn.com/media/image/9c/4e/8b/1023109_01_200x200..jpg)
![LK Alphacool Lüfterkabel 4-Pin auf 4-Pin Verlängerung 30cm](https://aquatuning.shop-cdn.com/media/image/c7/a2/ab/1023107_01_200x200..jpg)
![ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - 6pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/c8/29/f0/1022497_1gAlejgQeBmAEv_200x200..jpg)
