Phobya 4Pin Molex power extension - Black 60cm
- Article no.: KAB
- EAN: 4049469100810
- Weight: 0,027 kg
- Available:
Extension cable for connecting 4-pin Molex fans (CPU cooler, case fans, etc.) to power supply connector or other fan connector (3-pin Molex), approx. 62 cm long.
Sleeve:
Sets:
Technical details:
Connectors: 4Pin Molex
Color: black sleeve, black connector, black shrink tube
Dimensions: 60cm
1x Phobya 4Pin Molex power extension 60cm - Black
This product was tested for you:
Aqua info
Tech Review
Extremehardware ( it.)
1. Seite: | 1x 4Pin |
Sleeving: | schwarz |
Hersteller: | Phobya |
Bauform: | Verlängerung |
2. Seite: | 1x 4Pin |
Liefertermin: in 6 - 7 Wochen
Liefertermin: in 2 - 3 Tagen
