Phobya Y-cable 4Pin to 2x 4Pin single sleeving - black 20cm
- Article no.: LK
- EAN: 4049469122928
- Weight: 0,024 kg
1x4pin female to 2x4pin male for connecting two devices (e.g. drives) to one power supply connector.
Sleeve:
Sets:
Technical data:
Length: 20cm per strand
Color: black
Connection type: 4 pin Molex
Phobya Y-cable 4Pin to 2x 4Pin single sleeving 20cm - black
1. Seite: | 1x 4Pin |
Bauform: | Y-Kabel |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 2x 4Pin |
