Phobya Y-cable 3Pin Molex to 2x 3Pin Molex - Black 30cm
- Article no.: LK
- EAN: 4049469077822
- Weight: 0,011 kg
For connecting two 3-pin fans (radiator fan, case fan, etc.) to the mainboard connector (3-pin). Please note that when using the cable, speed monitoring is only possible for one of the connected fans.
Sleeve:
Sets:
Technical details:
Connectors: 3 pin to 2x 3 pin Y-cable
Colour: black sleeve, black connectors, black shrink tube
Dimensions: 30cm each
RoHS compliant
1x Phobya Y-cable 3Pin Molex to 2x 3Pin Molex 30cm - Black
Note: When using this distributor, please pay attention to the requirements of the slot, on the mainboard or the fan controller. Excessive loads, pay attention to the wattage of the fans, can lead to damage.
This product was tested for you:
Aqua info
Tech Review
Bauform: | Y-Kabel |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
2. Seite: | 2x 3Pin |
Liefertermin: in 6 - 7 Wochen
