Phobya Y-cable 4Pin PWM to 3x 4Pin PWM - Black 30cm
- Article no.: LK
- EAN: 4049469100155
- Weight: 0,019 kg
A Y-cable from a 4-pin PWM connector to 3x 4-pin PWM.
Since controlling and switching PWM fans via the mainboard is much more cost-effective than using a fan controller, this cable is ideal. This cable can be used to increase the small number of mainboard slots for this type of fan.
The adapter is supplied in a plain black. The cables are shielded with a matching sheath made of flex sleeves. It offers additional protection against abrasion. This increases the service life of the cables considerably. The ends near the connectors have been provided with shrink tubing to create a clean transition.
A notice:
Two of the three cables are missing the speedometer signal cable because only one signal per connection on the mainboard can be recognized. A white sticker on the cable shows which one is transmitting the speedometer signal.
Sleeve:
Sets:
Technical details:
Connections:
1x 4Pin PWM male connector
3x 4Pin PWM female connector
Color: black sleeves, black connectors, black shrink tubing
Dimensions: complete 30cm
RoHS compliant
1x Phobya Y-cable 4Pin PWM to 3x 4Pin PWM 30cm - Black
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 3x 4Pin PWM |
