Alphacool Eisblock Aurora RTX 4070TI Ventus with backplate
  • 13724
  • 4250197137249
  • 1,23 kg
€119.98 * €159.98 * (25% Saved)
€59.98*
€16.98*
ANZ Alphacool Eiszapfen screw plug V.2 G1/4 - Deep Black
€2.98*
€33.97*
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
€16.98*
€6.49*
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics... more
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- MSI GeForce RTX 4070 Ti Ventus 3X 12G OC, 12GB GDDR6X (V513-001R)
- MSI GeForce RTX 4070 Ti Ventus 3X 12G, 12GB GDDR6X
- MSI GeForce RTX 4070 Ti SUPER 16G Ventus 2X OC, 16GB GDDR6X (V513-615R)
- MSI GeForce RTX 4070 Ti SUPER 16G Ventus 2X, 16GB GDDR6X
- MSI GeForce RTX 4070 Ti SUPER 16G Ventus 3X OC, 16GB GDDR6X
- MSI GeForce RTX 4070 Ti SUPER 16G Ventus 3X, 16GB GDDR6X
Technical data cooler
Dimensions (L x W x H)171,50 x 132,50 x 33,97mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs12
Colortransparent
Technical data backplate
Dimensions (L x W x H)171,50 x 108,00 x 6mm
Materialaluminium
Manufacturer: Alphacool
Cooler type: Complete cooler
Material base plate: Copper
Material Lid: Acrylic
Dimensions: 171,50 x 132,50 x 33,97mm
Connection: 4x G1/4"
Hardware model: RTX 4070 Ti
RAD Alphacool NexXxoS ST30 Full Copper 280mm Radiator
€54.98 *
Liefertermin: in 6 - 7 Wochen
€6.49 * €8.98 *
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 200 Aurora reservoir acetal/acrylic with Apex pump
€89.98 * €124.99 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Liefertermin: in 2 - 3 Wochen
WAC Alphacool Core 1 Aurora White
€129.98 *
€33.97 *
Alphacool Ice Water Crystal Clear UV-active Ready Mix 1000ml
Content 320 Zentimeter (€6.24 * / 100 Zentimeter)
Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
Content 240 Zentimeter (€6.24 * / 100 Zentimeter)
