Phobya 4Pin PWM Male to Male - Black 30cm
- Article no.: LK
- EAN: 4049469206673
- Weight: 0,008 kg
Cable is covered with black sleeving and has black connectors.
Technical data:
- 1. Side: 4 pin PWM connector
- 2nd side: 4 pin connector
- length: 30cm
- 1x Phobya 4Pin PWM male to male 30cm - Black
1. Seite: | 1x 4Pin PWM |
Bauform: | Adapter |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin PWM |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/54/15/0f/1012291_1Cy4aIYYdTb5j4_200x200..jpg)
![KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 15cm](https://aquatuning.shop-cdn.com/media/image/b8/ca/3d/1023138_01_200x200..jpg)
![MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm](https://aquatuning.shop-cdn.com/media/image/58/57/44/1013684_1ImwE0Y1423Ra0_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/7f/40/da/81092_1MzMueJ4xNN7xz_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/b4/7a/06/81086_1jJ5qbCz3P4VkA_200x200..jpg)
![KAB Alphacool Verlängerung aRGB 3-Pin auf 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/e9/a5/bb/1023139_01_200x200..jpg)
![LK Alphacool Y-Splitter 4-Pin auf 3x 4-Pin PWM 15cm](https://aquatuning.shop-cdn.com/media/image/04/08/a0/1023112_01_200x200..jpg)
![ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - 6pcs Set Deep Black](https://aquatuning.shop-cdn.com/media/image/c8/29/f0/1022497_1gAlejgQeBmAEv_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM 2x 4Pin PWM - Schwarz 10cm](https://aquatuning.shop-cdn.com/media/image/ef/dc/63/81137_19SAJsYnOb1GCu_200x200..jpg)
![LK Phobya 4Pin PWM auf 3x 4Pin PWM Verlängerung - Schwarz 40cm](https://aquatuning.shop-cdn.com/media/image/52/6e/98/81123_1oXo0LT7lUuIj7_200x200..jpg)
![LK Phobya Verlängerung 3Pin Molex extra lang - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/78/1c/07/81033_1ipZON9lFQDWAz_200x200..jpg)
![KAB Alphacool Eiskamm Alu X16 - 4mm black - 4 Stück EOL](https://aquatuning.shop-cdn.com/media/image/5a/74/63/1013650_1QGgxuwZfMlqgh_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 4x 3-Pin 60cm](https://aquatuning.shop-cdn.com/media/image/a1/78/b1/1023149_01_200x200..jpg)
![KAB Alphacool Y-Splitter aRGB 3-Pin auf 2x 3-Pin 15cm](https://aquatuning.shop-cdn.com/media/image/c9/77/f1/1023141_01_200x200..jpg)
![LK Alphacool Y-Splitter 3-Pin auf 4x 3-Pin 30cm](https://aquatuning.shop-cdn.com/media/image/52/3d/53/1023132_01_200x200..jpg)
