Phobya 4Pin PWM Extension - Black 30cm
- Article no.: LK
- EAN: 4049469100032
- Weight: 0,01 kg
An extension of a PWM connector (4 pin).
Since controlling and switching PWM fans via the mainboard is much more cost-effective than using a fan controller, this cable is ideal.
The extension cable is supplied in a plain black. The cables are shielded with a matching sheath made of flex sleeves. It offers additional protection against abrasion. This significantly increases the service life of the cables. The ends near the connectors have been provided with shrink tubing to create a clean transition.
Sleeve:
Sets:
Length: 30cm
Color: black
Connection type: 4 pin PWM
1x Phobya 4Pin PWM extension 30cm - Black
This product was tested for you:
Aqua info
Tech Review
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin PWM |
Bauform: | Verlängerung |
Liefertermin: in 2 - 3 Tagen
