Phobya Y-cable for PWM splitter 4Pin PWM to 4Pin PWM & 4Pin Molex - Black 50cm
- Article no.: LK
- EAN: 4049469206406
- Weight: 0,02 kg
Phobya Y-cable for PWM splitter 4Pin PWM to 4Pin PWM & 4Pin Molex.
Since controlling and switching PWM fans via the mainboard is much more cost-effective than using a fan controller, this cable is ideal. This cable can be used to increase the small number of mainboard slots for this type of fan. Alternatively, the 4-pin Molex can be used to supply power to the two PWM fans.
The adapter is supplied in a simple black. The cables are shielded with a matching sheath made of flex sleeves. It offers additional protection against abrasion. This increases the service life of the cables considerably. The ends near the connectors have been provided with shrink tubing to create a clean transition.
Sleeve:
Sets:
Technical details:
- Connections:
- 2x 4 PIN PWM female connector
- 1x 4Pin Molex connector
- Colour: black sleeve, black connectors, black shrink tube
- Dimensions: complete 50cm
- RoHS compliant
- 1x Phobya Y-cable for PWM splitter 4Pin PWM to 4Pin PWM & 4Pin Molex 50cm - black
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 1x 4Pin PWM |
![LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL](https://aquatuning.shop-cdn.com/media/image/1e/f3/7e/81028_1TUhirHLck7yLz_200x200..jpg)
![LK Phobya Verlängerung 3Pin - UV Blau 30cm EOL](https://aquatuning.shop-cdn.com/media/image/0c/58/d0/81030_1mQyy9ZN1UbEYH_200x200..jpg)
![LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/01/66/c6/81049_1ldz6clB4id7j0_200x200..jpg)
![LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) 20cm EOL](https://aquatuning.shop-cdn.com/media/image/e8/c0/28/81067_1U2CudqeNwLq5u_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/25/9d/04/1011110_1Wj6PAymPH3MMp_200x200..jpg)
![LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm](https://aquatuning.shop-cdn.com/media/image/bb/58/d6/81134_1LL5rBsrWLnfwo_200x200..jpg)
![ANS Alphacool HF Anschraubtülle TPV Metall - 12,7/7,6mm Gerade - Black - 6er Kit](https://aquatuning.shop-cdn.com/media/image/54/43/08/1016782_1_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube TPV 12,7/7,6 - Black Matte 3,3m (10ft) Retailbox 330cm](https://aquatuning.shop-cdn.com/media/image/af/19/86/1016779_1_200x200..jpg)
![KAB Alphacool Y-Kabel RGB 4pol auf 3x 4pol inkl. Stecker - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/76/83/fc/1013985_1sxFhmIjI26aUZ_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/3d/80/86/1011109_1_200x200..jpg)
![WAK Alphacool Eisblock Aurora Geforce RTX 4090 GameRock + Phantom mit Backplate](https://aquatuning.shop-cdn.com/media/image/c0/78/8e/1023376_1qIyach7RIC9x4_200x200..jpg)
![LED Alphacool Aurora Flexlight - RGBW 30cm EOL](https://aquatuning.shop-cdn.com/media/image/90/22/20/1014210_1xnWl7rmvZRGlJ_200x200..jpg)
![LK Phobya 4Pin PWM Stecker auf Stecker - Schwarz 60cm](https://aquatuning.shop-cdn.com/media/image/54/15/0f/1012291_1Cy4aIYYdTb5j4_200x200..jpg)
![ANS Alphacool Eiszapfen 16/10mm Anschraubtülle G1/4 - Deep Black Sixpack](https://aquatuning.shop-cdn.com/media/image/c8/13/36/1011163_1d5LginqNaeo4y_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL](https://aquatuning.shop-cdn.com/media/image/fe/95/9f/1011111_1aIOZNK7lZCfVK_200x200..jpg)
![LK Phobya Y-Kabel 4Pin PWM 2x 4Pin PWM - Schwarz 10cm](https://aquatuning.shop-cdn.com/media/image/ef/dc/63/81137_19SAJsYnOb1GCu_200x200..jpg)
![S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - Klar 3m (9,8ft) Retailbox 300cm](https://aquatuning.shop-cdn.com/media/image/1c/a4/97/59306_1R5taET7SXWI1I_200x200..jpg)
![KAB Phobya RGB 4pol Verlängerung - Schwarz 150cm](https://aquatuning.shop-cdn.com/media/image/49/59/17/87479_1N9hdKa6ZTIntV_200x200..jpg)
![LK Phobya Adapter 4Pin Molex (12V) auf 4Pin PWM - Schwarz 30cm](https://aquatuning.shop-cdn.com/media/image/02/8e/78/81118_1Famq00dSUEGBl_200x200..jpg)
![LK Phobya Y-Kabel 4Pin auf 2x 4Pin Einzel Sleeving - Schwarz 20cm](https://aquatuning.shop-cdn.com/media/image/58/75/c1/81117_1EI30eJQvhZfXR_200x200..jpg)
