Phobya Y-cable 4Pin PWM to 3x 4Pin PWM - Black 60cm
- Article no.: LK
- EAN: 4049469193355
- Weight: 0,025 kg
- Available:
A Y-cable from a 4-pin PWM connector to 3x 4-pin PWM.
Since controlling and switching PWM fans via the mainboard is much more cost-effective than using a fan controller, this cable is ideal. This cable can be used to increase the small number of mainboard slots for this type of fan.
The adapter is supplied in a plain black. The cables are shielded with a matching sheath made of flex sleeves. It offers additional protection against abrasion. This increases the service life of the cables considerably. The ends near the connectors have been provided with shrink tubing to create a clean transition.
A white sticker on the cable indicates which one transmits the speedometer signal.
Sleeve:
Sets:
Technical details:
Connections:
1x 4Pin PWM male connector
3x 4Pin PWM female connector
Color: black sleeves, black connectors, black shrink tubing
Dimensions: complete 60cm
RoHS compliant
1x Phobya Y-cable 4Pin PWM to 3x 4Pin PWM 60cm - Black
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 3x 4Pin PWM |
