Yate Loon D90BH-12 with plug (2600rpm) (92x92x25mm)
- Article no.: L92
- EAN: 4049469280444
- Weight: 0,085 kg
Yate Loon offers fans with particularly high static pressure and high air flow. They are particularly suitable for use as powerful case fans and also offer extremely high performance on radiators of a water cooler. The classic frame means they completely cover radiators, meaning all the air is actually pushed through the radiator. The fans can be easily controlled via the voltage using the 3-pin connector.
Technical data:
Dimensions: 92 x 92 x 16.5mm
Connector: 3-pin
Supply voltage: 12V
Power consumption: 2.76W
Starting voltage: 6.5V
Speed: 2600 rpm
Air flow rate: 45.87 m³/h
Static pressure: 2.1 mm/H²O
Noise level: 34 dB(A)
Cable length: 55cm
Nennspannung: | 12V DC |
LED: | nicht vorhanden |
Stromanschluss: | 3Pin |
Luftförderbereich: | 50 - 99 m³/h |
Größe: | 92mm |
Lautstärkebereich: | 20 - 29,9 dB(A) |
Hersteller: | Yate Loon |
Abmessungen: | 92 x 92 x 15mm |
Nenndrehzahl: | 2600 U/min |
RPM Signalübertragung: | Nein |
Farbe Rahmen: | schwarz |
Farbe Rotor: | schwarz |
