Alphacool ice cyclone Aurora LUX PRO Digital RGB (200x200x25mm)
- Article no.: 24815
- EAN: 4250197136174
- Weight: 0,194 kg
The Alphacool Eiszyklon Aurora LUX PRO 200mm fan offers a wide control range as well as outstanding digital RGB LED lighting. The individually controllable 5V aRGB LEDs paired with the special design of the fan frame create unique effects.
Brilliant lighting
Digitally addressable 5V RGB LEDs are installed in the frame, which illuminate the entire frame on the front. The frame is not completely transparent, but rather the lighting comes from narrow slits that are interrupted at four points. There are two rows of these slit-shaped recesses on the top. One narrow frame runs along the inside and one along the outside of the frame. This creates a unique lighting that looks very classy. Thanks to the embedded diffusers, the light is distributed evenly. This avoids spot lighting. Individual LEDs are no longer visible.
Wide control range and silent
The fan can be controlled from 400 to 800 rpm using the 4-pin PWM connection. At 400 rpm, the fan is almost silent, but still offers a good air flow coupled with a high static pressure. This means that the fan can also be used very well on radiators for water cooling. Thanks to the high air flow, the fan is also ideal for ventilating a case. There are also decouplers directly on the frame. The soft foam padding reduces the transmission of vibrations to the case. Another plus point for the fan's silent capabilities.
Connections?
The fan is controlled via a 4-pin PWM connection. The cable is 48 cm long. This means that the fan can be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
Technical data:
L x W x H: 200 x 200 x 27 mm
Weight: 343g
Speed: 400 - 800rpm
Fan bearing: Rifle bearing
Fan connection: 4-pin PWM
Digital RGB connector: 3-pin JSP + 3-pin 5V
Fan cable length: 48 cm
Cable length Digital RGB: 48cm
Fan operating voltage: 12V
Operating voltage Digital RGB: 5V
Current consumption: 0.14A (1.68W)
Static pressure: 1.3 - 1.52 mm H2O
Air flow: 27 - 56 m³/h
Volume: 7.4 - 23.7 dB(A)
MTBF: 50,000 hours
Download data sheet PDF: Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
Nennspannung: | 12V DC |
Stromanschluss: | 4Pin |
RPM Signalübertragung: | Ja |
Lautstärkebereich: | 10 - 19,9 dB(A) |
Luftförderbereich: | 50 - 99 m³/h |
Nenndrehzahlbereich: | 0 - 950 U/min |
Lebensdauer (bei 25°C): | 50.000 h |
Leistungsaufnahme: | 1,68W |
Größe: | 200mm |
Abmessungen: | 200 x 200 x 25mm |
Nenndrehzahl: | 950 U/min |
Druck: | 1,52mm H2O |
Luftförderleistung: | 27 - 56 m³/h |
Lautstärke: | 7,4 - 23,7 dB(A) |
Farbe Rahmen: | schwarz |
Farbe Rotor: | schwarz |
LED: | ARGB |
