Alphacool Eisblock XPX Pro Aurora - Full Brass Chrome Digital RGB
- Article no.: 13086
- EAN: 4250197130868
- Weight: 1,38 kg
With the Alphacool XPX Aurora Pro Eisblock, Alphacool offers a CPU water cooler specially designed for processors with particularly large processor cores. These currently include the AMD Threadripper models and processors from Intel for the LGA 2066 socket and the LGA 3647 server socket in narrow ILM design. As a CPU cooler from the Aurora Design line, the CPU cooler naturally offers integrated digital aRGB lighting.
Extremely powerful
The cooler base has been specially optimized for the large processor cores. With an area of 42 x 58.6 mm and 147 cooling fins the cooling area has been significantly increased. As a comparison, an Alphacool XPX Aurora Eisblock has 81 cooling fins to completely cover the processor core of a normal CPU. Both coolers use the same fin type with a thickness of only 0.2 mm. This clearly shows how far Alphacool has gone to offer the best possible performance. The entire cooler base is of course made of nickel-plated copper and not aluminium. This is due to the increased thermal conductivity of copper. It is almost twice as high as that of aluminium.
Lighting
Behind the Alpahcool logo, 2 digitally addressable 5V RGB LEDs are installed, which create a unique, very noble-looking illumination. The digital aRGB LED lighting is connected via a JST 3-pin connector. To control the digital RGB lighting, the enclosed adapter must be connected to the 3-pin female connector and connected to a digital RGB controller or a digital RGB-capable mainboard. Additional digital RGB LEDs can be connected to the remaining 3-pin male connector.
Discreet appearance
The matt finish gives the cooler, which is made entirely of brass (except for the cooler bottom), a noble look. This makes it interesting for users who prefer a discreet appearance and want to do without a complex aRGB illumination.
Thermal grease
The thermal paste included in the delivery is Alphacool's Subzero with a thermal conductivity of 16 W/mk. The electrically non-conductive thermal grease is particularly suitable for high contact pressures, but can still be processed perfectly due to its viscosity of 850000 TF.
Intel: LGA 1700 / LGA 1851 / LGA 2011-3 / LGA 2066 / LGA 3647 / LGA 4189 (optional) / LGA 4677 (optional)
Technical data | |
L x W x H | 76,5 x 63,5 x 31mm |
Material cooler | nickel plated copper |
Material bottom part | brass |
Material top | brass |
Number of aRGB LEDs | 2 |
Threads | 2 x G1/4“ |
Power supply Digital aRGB | 3-Pin 5V |
Pressure tested | 0,8 bar |
Net weight | 705g |
Color | chrome |
Base: | AMD AM4, AMD AM5, AMD SP3, AMD SP6, AMD sWRX8, AMD TR4, AMD TR5, Intel 2011(-3), Intel 2066, Intel LGA 1700, Intel LGA 1851, Intel LGA 3647, Intel LGA 4189, Intel LGA 4677 |
Dimensions (L x W x H: | 76,5 x 63,5 x 31mm |
Connection: | 2x G1/4" |
Material base plate: | Nickel-plated copper |
Material Lid: | Brass |
Liefertermin: in 2 - 3 Wochen
Liefertermin: in 6 - 7 Wochen
Liefertermin: in 4 - 5 Tagen
