Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Suprim with backplate
- Article no.: 14486
- EAN: 4250197144865
- Weight: 5,78 kg
- Available: Currently there are 4 available - More is on the way
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- MSI GeForce RTX 4090 Gaming Trio 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Gaming X Trio 24G, 24GB GDDR6X (V510-006R)
- MSI GeForce RTX 4090 Suprim Liquid X 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Suprim X 24G, 24GB GDDR6X (V510-001R)
Technical data radiator | |
Material threads | Brass |
For fan size | 120 mm |
Dimensions (L x W x H) | 266,6 x 169,5 x 46,1mm |
Threads | 2 x G1/4“ |
Pump type | DC-LT 2 |
Head of delivery | 1 m |
Maximum flow rate | 72 L/h |
Voltage | 6-13.5V DC |
Power consumption | 3.2W |
MTBF | 50.000 h |
Technical data liquid | |
Color | clear |
L x D | 95 x 27mm |
Material | Nylon |
Color | Black |
Technical data fittings | |
Quantity 90° fittings | 2x |
Material fittings | Brass |
Technical data tube | |
Length | 50cm |
Color | Matt black |
Tube size | 12,7 / 7,6mm |
Technical data fan | |
Speed | 0 - 2500 RPM |
Air flow rate | 119,8 m³/h |
Bearings | Sleeve bearing |
Fan connector | 4-Pin PWM |
Net weight | 187g |
Radiator dimensions: | 395 x 124 x 30mm |
Radiator thickness: | 29 - 39mm |
Radiator size: | 360mm |
Hose dimensions: | 12,7/7,6mm |
Base: | Nvidia GeForce; |
Prefilled: | Yes |
