Alphacool Eiswolf 2 AIO - 360mm RTX 4090 Suprim with backplate
  • 14486
  • 4250197144865
  • 5,78 kg
€169.98 * €269.98 * (37.04% Saved)
€59.98*
12948 Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€59.98*
ROH Alphacool Eisbaer TPV Extension Set (hose and connections)
€15.39*
WAKZ Alphacool Aurora Vertical GPU Mount with Riser Cable
€76.98*
WZS Alphacool spray bottle Core 500ml
€4.98*
The Alphacool Eiswolf 2 is the first full cover GPU AIO waterblock from Alphacool. It is based... more
Fullcover Waterblock?
Chrome-plated copper
Pump
Fittings and Tubing
Expandability
Lighting and fans
NexXxoS Radiator
Technical note!
- MSI GeForce RTX 4090 Gaming Trio 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Gaming X Trio 24G, 24GB GDDR6X (V510-006R)
- MSI GeForce RTX 4090 Suprim Liquid X 24G, 24GB GDDR6X
- MSI GeForce RTX 4090 Suprim X 24G, 24GB GDDR6X (V510-001R)
Technical data radiator
Dimensions (L x W x H)395 x 124 x 30mm (+/- 3%)
Material cooling fins, chambers & channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes (+ 1x Fillport G1/4“)
For fan size120 mm
Options for fan assembly3 x one-sided / 6 x both-sided
Technical data cooler and pump
Dimensions (L x W x H)266,6 x 169,5 x 46,1mm
Material cooler bottomChrome plated copper
Material cooler topacrylic
Threads2 x G1/4“
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Head of delivery1 m
Maximum flow rate72 L/h
Voltage6-13.5V DC
Power consumption3.2W
MTBF50.000 h
Technical data liquid
Colorclear
Ingredient 1Destilled water (CAS-number 7732-18-5)
Ingredient 2Glysantin (CAS-number 1017-21-1)
Working temperatures-15 C° / +90 °C
Technical data quick fasteners
L x D95 x 27mm
MaterialNylon
For tube size12,7 / 7,6mm
ColorBlack
Technical data fittings
L x D straight fitting24 x 18mm
Quantity straight fittings2x
L x B x H 90° fitting35 x 27 x 17mm
Quantity 90° fittings2x
Material fittingsBrass
Technical data tube
Length50cm
Material tubeTPV (EPDM/PP)
ColorMatt black
Tube size12,7 / 7,6mm
Hardness grade35 Shore-A to 50 Shore-D
Working temperature-50 to +155 °C
Technical data fan
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
BearingsSleeve bearing
Fan connector4-Pin PWM
Dimensions (L x W x H)120 x 120 x 25mm
Net weight187g
Max working temperature60°C
Made in: China
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: Nvidia GeForce;
Prefilled: Yes
KOI Alphacool Eisbaer Pro Aurora 420 CPU AIO
€239.98 *
Content 6 Stück (€3.00 * / 1 Stück)
WAK Alphacool Core Geforce RTX 5090 ROG Astral mit Backplate
Alphacool Core Geforce RTX 5090 ROG Astral with backplate
€209.98 *
SEN Alphacool Thermosensor einzeln 50cm
Alphacool Thermosensor single 50cm
€2.68 *
Alphacool Core thermal pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Alphacool Core thermal pad Soft 9W/mk 100x100x1mm
Content 100 cm² (€0.22 * / 1 cm²)
€21.98 *
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
€29.98 *
€6.28 *
€4.98 *
Delivery date: in 5 - 6 days
33%
WÄM Alphacool Rise Wärmeleitpaste 6W/mK 4g
€5.99 * €8.98 *
21%
WÄM Alphacool Subzero Thermal grease 20g
€33.97 * €42.98 *
S16 Alphacool Schlauch AlphaTube TPV 16/10 - Black Matte 50m Rolle
Alphacool hose AlphaTube TPV 16/10 - Black Matte 50m roll
Content 5000 Zentimeter (€5.40 * / 100 Zentimeter)
€269.98 *
