Alphacool Core DDCzero Flat Reservoir 90 with Pump
  • 14567
  • 4250197145671
  • 0,61 kg
€159.98 *
€15.98*
13446 Alphacool Core 1 Aurora Black
€125.98*
13768 Alphacool Core XT45 Full Copper 240mm Radiator
€157.98*
14894 Alphacool Apex Grip offset 27mm 2x 90° OT/IT G1/4 rotatable chrome
€29.98*
14927 Alphacool Apex Grip HardTube fitting 13mm G1/4 chrome Set 6 pcs
€46.98*
The Alphacool Core DDCzero Flat Reservoirs combine a compact reservoir with the powerful... more
The Alphacool Core DDCzero Flat Reservoirs combine a compact reservoir with the powerful Alphacool DDCzero PWM pump. Thanks to their flat design, they are particularly well suited for small-form-factor systems. The series is available in various sizes, allowing flexible adaptation to different case layouts and cooling concepts.
The base of the Core DDCzero Flat Reservoirs is made of durable acetal. The transparent top is manufactured from high-quality acrylic and provides an unobstructed view inside the reservoir.
The G1/4" connection threads are integrated directly into the robust acetal base. This avoids delicate threads in the acrylic and ensures a stable and reliable connection. Five G1/4" ports provide numerous options for integrating the reservoir into the cooling loop. The inlet, outlet, filling and draining ports can be flexibly adapted to the tubing layout of the respective cooling system.
The integrated digitally addressable aRGB lighting effectively highlights the coolant and provides even illumination throughout the reservoir. The lighting can be controlled via a compatible digital aRGB header on the motherboard or a suitable aRGB controller (Art.-No. 15360).
The clean, linear design and the carefully considered positioning of the ports integrate seamlessly into the Alphacool Core series.
The 90 variant is the most compact model in the series. Thanks to its small dimensions, it is particularly suitable for small cases and systems with severely limited installation space.
The integrated Alphacool DDCzero PWM pump is a compact and powerful circulation pump for PC water-cooling systems, datacenter systems and industrial applications. A robust ceramic shaft, combined with the durable plastic housing, ensures reliable and long-lasting operation. The pump offers strong performance and ensures a dependable coolant flow. Its speed can be flexibly adjusted across a wide control range to meet the individual requirements of the system.
The Alphacool DDCzero PWM pump is connected to the motherboard or a suitable controller via a 4-pin fan connector. This connector supplies power to the pump, enables PWM control and transmits the speed signal. PWM control allows the pump performance to be adjusted specifically to the current system load. This enables a balanced operation between high cooling performance and the lowest possible noise level.
The Alphacool Core Universal Mounting Kit is included in the scope of delivery. It enables easy installation and securely holds the Core DDCzero Flat Reservoirs on radiators or fan mounting positions in the 120 mm format. Using the Alphacool Core Universal Mounting Kit, the reservoirs can be installed in two different orientations: straight or rotated by 90°.
Compatibility
The Alphacool DDCzero pump tops and reservoirs are exclusively compatible with the Alphacool Core DDCzero PWM pump. Standard DDC pumps cannot be used due to their larger dimensions.
Dimensions (L x W x H) (in mm)93,00 x 63,00 x 44,10
Material baseAcetal
Material topAcryl
Number of connections5x
Material connection threadAcetal
ThreadsG 1/4
Maximum torque G1/4 thread (in Nm)1,00
Maximum torque M2 thread (in Nm)0,13
Maximum torque M2,5 thread (in Nm)0,27
Maximum torque M3 thread (in Nm)0,48
Maximum torque M4 thread (in Nm)1,12
Maximum operating temperature (in °C)60
Minimum operating temperature (in °C)-20
Maximum tested pressure (in bar)2,00
Recommended working pressure (in bar)0,0 - 1,0
Maximum filling volume (in ml)26
LED quantity and length5pc. / 81,00mm
LED Voltage5V DC
LED Ampere0,06A
LED Power1,5W
LED Cable lengths (in cm)38
Technical data pump
Dimensions (D x H)46,00 x 24,20mm
Material pump housingPlastic
Material pump coverPlastic
Material axleCeramic
Connections4-Pin PWM
Power6,2W
Rotational speed3000 - 4800 RPM
Cable lengths4-Pin PWM - 48cm
Starting voltage12V DC
Maximum pumping head1,4m
Maximum flow rate220L/h
Weight50g
ColorBlack
Awards & Videos
S16 Alphacool EPDM Tube 16/10 - Schwarz 1m (3,28ft) Retailbox
Alphacool EPDM Tube 16/10 - black 1m (3,28ft) Retailbox
Content 1 Laufende(r) Meter
€5.99 *
S13 Alphacool EPDM Tube 13/10 - Schwarz 1m (3,28ft) Retailbox
€4.97 *
WAC Alphacool Core 1 Silver
Alphacool Eiszapfen Pro 13mm spare parts
€1.98 *
Alphacool Eisblock XPX Pro 1U
€11.98 *
€25.98 *
€3.48 *
