Alphacool EPDM Tube 16/10 - black 1m (3,28ft) Retailbox
- Article no.: 5100121
- EAN: 4070201001218
- Weight: 0,21 kg
*1The EPDM tube from Alphacool's Enterprise Solutions series is characterised by its high resistance to acids, alkalis and external influences and has exceptional longevity compared to conventional PVC tubes. The matt black hose with its discreet velvet look will quickly become an eye-catcher in any water-cooled PC.
What is the advantage of EPDM?
Compared to commercially available PVC tubing, the EPDM tube from Alphacool is significantly more temperature resistant and enables working temperatures far above 100 °C. Even at higher water temperatures, the EPDM Tube remains dimensionally stable and prevents the hose from warping at points with tighter bending radii or connections. The risk of the water loop leaking or the water flow being obstructed is thus eliminated. The high resistance to external influences makes the Alphacool EPDM tube extremely durable and long-lasting.
Mounting
The Alphacool EPDM tube is slightly more dimensionally stable compared to a PVC tube. Nevertheless, it has an excellent pliability as well as flexibility for an effortless assembly even with tighter bending radii.
Fittings
The EPDM tube can be used with all tube fittings (in the appropriate size) from the Alphacool Eiszapfen or HF series.
| Technical data | |
| Length | 1m (3,28ft) |
| Material tube | Ethylene propylene diene rubber (EPDM, without talc) |
| Tube size | Ø outside 16 mm / Ø inside 10 mm (tolerances according to DIN ISO 33-02-1 E1) |
| Hardness grade | 75° (± 5°) Shore A |
| Working temperature | -35° C bis +120° C |
| Color | matt black |
Warranty: 10 years
