Alphacool Core universal bracket set for DDCzero reservoir
RAB Alphacool Core Universalhalterungsset für DDCzero Reservoir
  • 14727
  • 4250197147279
  • 0,155 kg
13867 Alphacool Core DDCzero 3300-4800rpm PWM Pump
€69.98*
14567 Alphacool Core DDCzero Flat Reservoir 90 with Pump
€159.98*
14568 Alphacool Core DDCzero Flat Reservoir 140 with Pump
€179.98*
14572 Alphacool Core 2x DDCzero Flat Reservoir 200 with Pump
€199.98*
The Alphacool Core Universal Mounting Kit was developed specifically for installing Alphacool... more
The Alphacool Core Universal Mounting Kit was developed specifically for installing Alphacool Core DDCzero reservoirs. It enables easy and flexible mounting on radiators or fan mounting positions in the 120 mm format.
The Universal Mounting Kit allows compatible DDCzero reservoirs and pump tops to be installed in two different orientations. Depending on the available installation space and the desired tubing layout, they can be mounted either straight or rotated by 90°.
This allows the position to be adapted flexibly to the layout of the respective system. It facilitates integration into compact cases, densely populated water-cooling systems and individual system configurations.
The stable construction ensures a secure fit at the intended mounting position. The mounting kit reliably attaches the reservoir to the radiator or fan mounting position.
Installation is carried out using standardized mounting points for 120 mm fans. This allows the mounting kit to be used on numerous radiators and case mounting positions without requiring extensive additional modifications.
The Alphacool Core Universal Mounting Kit is intended for compatible reservoirs and pump tops from the Alphacool Core DDCzero series. It is not suitable as a universal mounting solution for arbitrary reservoirs or pump tops.
Reservoirs and Pumptops from the Alphacool Core DDCzero Series
Dimensions (L x W x H) (in mm)119,00 x 113,65 x 20,10
Material of the bracketsStainless steel
Material of the screwsStainless steel
Maximum torque M3 thread (in Nm)0,48
Mounting compatibility120mm fan screw holes
Sheet thickness2,00mm
Awards & Videos
Alphacool Eiszapfen Pro 13mm spare parts
€1.98 *
€11.98 *
€3.48 *
