Alphacool Core Flat Reservoir 360 Right D5 with VPP Apex PWM pump
  • 15488
  • 4250197154888
  • 2,296 kg
€262.48 *
€19.98*
€15.98*
17477 Alphacool Eiszapfen PRO 16mm HardTube fitting G1/4 - deep black sixpack
€39.98*
€14.98*
13823 Alphacool Apex Stealth Metal Power fan 3000rpm matte black (120x120x25mm)
€21.98*
The Alphacool Core Flat Reservoir not only looks sleek with its aRGB lighting, but also offers... more
The Alphacool Core Flat Reservoir not only looks sleek with its aRGB lighting, but also offers flexibility with a total of 5 connections. The reservoir is made entirely of acrylic. Due to its flat design, the Core Flat Reservoir also fits in small cases. A VPP Pump is already pre-mounted.
Core Design
A key element of Alphacool's Core Design series are the chrome-plated G1/4" connections made of brass. In the Core Flat Reservoir, the connections are recessed rather than screwed into a thread, bypassing the problem of possible leaks due to cracking from the direct screwing of the connections into the acrylic. The connections are in two parts, fitted with an O-ring and counter each other when mounted in the acrylic. This not only ensures absolute sealing of each connection, but also allows for the clear and functional appearance of the Alphacool Core Design series.
Easy installation
With the included Core Push Mounting kit, the Core Flat Reservoir can be mounted on the case panel or on a radiator. The metal pins are attached to the radiator or case panel and the matching female sleeves are attached to the Flat Reservoir (see manual). In the next installation step, the Flat Reservoir is simply and tool-free pushed onto the pins. Alphacool's Push-Mounting allows for a secure fit of the reservoir on the case panel or on the radiator and allows for easy disassembly for maintenance or expansion projects.
Gamechanger
The Core Flat Reservoir is offered as a 240mm or 360mm version, with right positioning of the pump top. This makes the reservoir ideal for custom water loops. An additional drain port is located on the side, allowing for easy and uncomplicated draining of the Flat Reservoir.
High-quality material selection & brilliant lighting
Alphacool's Core Flat Reservoir is made of high-quality acrylic glass, allowing for an unobstructed view of the coolant and brilliant illumination by the built-in digital addressable aRGB LEDs. The lighting can be controlled via a digital aRGB header on the motherboard or optionally through Alphacool's Aurora Eiscontrol aRGB controller (item number: 15360).
- Can be mounted on the radiator or panel
Dimensions (L x W x H)360,00 x 125,00 x 45,14mm
Volume (reservoir)500ml
MaterialAcryl
Pump compatibilityD5/VPP
Threads5x G1/4" inner thread / 1x drain port
Pressure tested0,8 Bar
Quantity digital aRGB LEDs17
Voltage digital aRGB LEDs5V
Power connection digital aRGB LEDs3-Pin JST + 3-Pin 5V
Colortransparent
Technical data pump
Dimensions (Flat Reservoir with pump) (L x W x H)360,00 x 125,00 x 91,79mm
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Weight276g
WAC Alphacool Core 1 White
€115.98 *
