Alphacool Apex Stealth Metal Power fan 3000rpm gold (120x120x25mm)
- Article no.: 13856
- EAN: 4250197138567
- Weight: 0,485 kg
Whisper Quiet
Powerful All-rounder
The Alphacool Apex Stealth metal fan is a true all-rounder. It sets new standards in terms of airflow and static pressure. Therefore, this fan is not only perfect for mounting on radiators, but also provides excellent airflow as a case fan. The Apex Stealth Power can be controlled between 400 to 3000 rpm via the 4-pin PWM connector. The startup speed is ~500 rpm. In addition, the Stealth offers Zero RPM control, which can be used to bring the fan to a complete stop.
Apex Design
Additional Features
Technical data | |
Dimensions (L x W x H) | 120 x 120 x 25,5mm |
Material (Frame) | Die-cast zinc |
Material (Impeller) | Plastic |
Weight | 320g |
Speed | 400~3000±10% rpm |
Bearing | Hydro Dynamic Bearing |
Connection | 4-Pin PWM |
Cable length PWM | 40±8 mm (+ 50cm extension cable) |
Cable length (daisy chain) | 110±10 mm |
Start-up Voltage | 6 V DC |
Rated Volt | 12 V DC |
Power Consumption | 6.60 Watt |
Rated Current | 0.50 A (0.55Max) |
Air Flow | 70.98 CFM |
Static Air Pressure | 4.23 mmH2O |
Noise Level | 40.1 dBA |
MTBF | 100,000h |
PWM control | Yes |
Zero RPM control | Yes |
Tacho Signal | Yes |
Auto-restart | Yes |
Color | gold |
Warranty: 5 years
Manufacturer: | Alphacool |
Rated speed range: | 400 - 3000 U/min |
Air conveying area: | 100 - 149 m³/h |
Air flow rate: | 120,595 m³/h |
Pressure: | 4,23 mm H2O |
Rated speed: | 3000 U/min |
Color Rotor: | Black |
Nominal voltage: | 12V DC |
Size: | 120mm |
Volume: | 40,2 dB(A) |
RPM signal transmission: | Yes |
Volume range: | 30 - 49,9 dB(A) |
Lebensdauer (bei 25°C): | 100.000 h |
Power connection: | 4Pin |
Dimensions: | 120 x 120 x 25mm |
LED: | Unavailable |
Power consumption: | 6,6W |
