Alphacool HardTube Bending Kit Basic
  • 29143
  • 4250197136280
  • 1 kg
  • Currently there are 5 available
€44.98 *
WZS Alphacool pull saw for acrylic/PETG pipes 35cm
€16.98*
SZ Alphacool Eiskoffer Professional - bending & measuring kit
€249.98*
€39.98*
With the Alphacool HardTube Bending Kit Basic you get all the products you need to trim, deburr... more
With the Alphacool HardTube Bending Kit Basic you get all the products you need to trim, deburr and bend your PETG tubes. The set is designed for hard tubes with 10 and 13 mm inner diameter.
Deburring made easy
Anyone who works with HardTubes knows that they have to deburr all ends of the tubes. The classic deburrer from Alphacool offers the possibility of deburring HardTubes inside and out. The external deburring is extremely important so that the HardTubes fit perfectly and no O-ring is damaged. The internal deburring is only used to remove cutting residues. The deburrer has three steel blades with sharpened edges for clean deburring. The deburrer fits perfectly in the hand thanks to its large, round shape.
Cutting PETG pipes
The Eistools Modding Cutter works like scissors and is ideal for easily cutting PETG HardTubes. However, it should be noted that acrylic HardTubes cannot be cut as they are too hard and would splinter when cut. Of course, it can also be used to cut cables and other soft components. If you want to cut angles, you can use the integrated protractor.
Bending tool and silicon inserts
A silicone insert is essential for bending hard tubes. The silicone insert prevents the tube from collapsing at the bends. The silicone insert is moistened before being inserted into the tube so that it slides better. Lubricants and too much soap should be avoided. Alcohol-like agents can attack PETG tubes. Simple angles can be easily bent with the small but practical bending tool. The tube is pushed into the bending tool, heated with a heat gun and simply bent around.
The only thing you need as a customer are the HardTubes and a hot air gun that can generate low temperatures. And then it's child's play to create a water cooling system with HardTubes.
1 x Silicon Bending Insert 100cm HardTubes with 13 mm inner diameter
1 x Silicon Bending Insert 100cm HardTubes with 10 mm inner diameter
1 x PETG and Acrylic Pipe Deburrer - Light Version
1 x Double Bending Tool for 12-14 and 16mm HardTubes
1 x Eistools Modding Cutter for PETG HardTubes
Datasheet PDF: Alphacool HardTube Bending Kit Basic
Content 320 Zentimeter (€6.87 * / 100 Zentimeter)
€21.98 *
Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€33.98 *
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
Content 35 Zentimeter (€48.51 * / 100 Zentimeter)
Content 240 Zentimeter (€7.08 * / 100 Zentimeter)
Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic/brass tubes - 4pcs
€33.98 *
Delivery date: in 5 - 6 days
ANS Alphacool HT 13mm HardTube Anschraubtülle G1/4 - gerändelt - Deep Black Sixpack PHT EOL
Alphacool HT 13mm HardTube screw-on nozzle G1/4 - knurled - Deep Black Sixpack
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
€47.98 *
Content 2 Stück (€15.99 * / 1 Stück)
€33.98 *
Content 320 Zentimeter (€6.24 * / 100 Zentimeter)
Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 60cm - Set of 4 (240cm)
Content 240 Zentimeter (€6.24 * / 100 Zentimeter)
€99.98 *
Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - White Sixpack
€33.98 *
€21.98 *
