power connector for 4Pin Molex
ZK Stromversorgungsstecker für 4Pin Molex
  • 82021
  • 4049469057268
  • 0,004 kg
€1.69 *
For our hobbyists: 4-pin Molex connector. This plug can be used to replace defective plugs.... more
This plug can be used to replace defective plugs. It can also be used as a basis to produce Y-connectors or extensions in your system without much effort. If you want to tidy up your system properly, for example to optimize the air flow or improve your cable management, there is no way around a DIY plug like this. Cables that are too long can be shortened and then fed back into the system using this plug. It is also possible to reduce the voltage output from 12 to 7 or even 5 volts by bending the connection cables - without an adapter. This is particularly interesting when operating fans that should run a little slower and therefore more quietly.
The assembly is child's play. The plug is sent in 2 components. The plastic plug itself and the tips with which the connection is made. The tips are simply inserted into the stripped cable end. The cable is tightened at the other end of the tips by pressing the tips together with pliers. This finished tip can now be pushed into the plastic plug. It now clicks into place and holds rock solid.
4 metal tips
1 plastic plug
75%
KAB Alphacool Eiskamm X4 - 3mm clear - 4 Stück EOL
Alphacool Ice Comb X4 - 3mm clear - 4 pieces
€0.99 * €3.89 *
75%
€0.99 * €3.89 *
€0.99 *
78%
€0.99 * €4.49 *
Alphacool VPP655 - PWM - Single Edition
€99.98 *
90%
€0.99 * €9.94 *
15%
WAK Alphacool Core Geforce RTX 4090 Strix + TUF mit Backplate PHT EOL
Alphacool Core Geforce RTX 4090 Strix + TUF with Backplate
€169.98 * €199.98 *
KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm EOL
Alphacool Mini USB to Mainboard USB 5-Pin 40cm
Content 40 Zentimeter (€7.45 * / 100 Zentimeter)
€2.98 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
Content 15 Zentimeter (€9.27 * / 100 Zentimeter)
€1.39 * €1.98 *
Content 24 Stück (€0.29 * / 1 Stück)
€6.99 *
21%
€33.97 * €42.98 *
20%
€3.97 * €4.97 *
