Alphacool Core Geforce RTX 4090 AMP with Backplate
  • 13481
  • 4250197134811
  • 2,006 kg
€69.98 * €199.98 * (65.01% Saved)
€19.98*
€12.98*
€18.98*
€241.98*
Alphacool's Core product series is characterized by high quality, outstanding performance and... more
- Manli GeForce RTX 4090 Gallardo, 24GB GDDR6X (N67540900M35300)
- Zotac Gaming GeForce RTX 4090 AMP Extreme AIRO, 24GB GDDR6X (ZT-D40900B-10P)
- Zotac Gaming GeForce RTX 4090 Trinity OC, 24GB GDDR6X (ZT-D40900J-10P)
- Zotac Gaming GeForce RTX 4090 Trinity, 24GB GDDR6X (ZT-D40900D-10P)
Technical data cooler
Dimensions (L x W x H)235,40 x 145,90 x 32,10mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom11,3mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs13
Colortransparent
Technical data backplate
Dimensions (L x W x H)235,40 x 122,90 x 5mm
Materialaluminium
Awards & Videos
43%
€3.97 * €6.99 *
€26.98 *
WAC Alphacool Core 1 Silver
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.23 * / 1 cm²)
€5.58 * €7.98 *
€2.58 *
€34.98 *
