Alphacool Core Geforce RTX 5080/5070 Ti Solid Core with Backplate
- Article no.: 14845
- EAN: 4250197148450
- Weight: 1,454 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Zotac Gaming Geforce RTX 5070 Ti Solid SFF OC 16GB (ZT-B50710J3-10P)
- Zotac GeForce RTX 5070 Ti SOLID CORE (ZT-B50710D2-10P)
- Zotac GeForce RTX 5070 Ti SOLID CORE OC (ZT-B50710J2-10P)
- Zotac Gaming Geforce RTX 5080 Solid CORE OC 16GB (ZT-B50800J2-10A)
- Zotac GeForce RTX 5080 SOLID CORE (ZT-B50800D2-10P)
- Zotac GeForce RTX 5080 SOLID CORE OC (ZT-B50800J2-10P)
| Technical data cooler | |
| Dimensions total (L x W x H) | 227,50 x 128,33 x 34,07mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 10 |
| Color | transparent |
| Dimensions (L x W x H) | 227,50 x 99,80 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
