Alphacool Core Hurrican 360mm XT45 HardTube water cooling set
- Article no.: KOI
- EAN: 4250197119931
- Weight: 7,26 kg
With the Core Hurrican HardTube water cooling set, Alphacool provides all the components needed to get started in the world of water cooling. The set is aimed not only at beginners, but also at enthusiasts. The selected components are optimally coordinated and come from Alphacool's DIY program. When choosing materials, the company continues to uncompromisingly use copper or brass for all metals in order to guarantee performance-oriented CPU cooling.
Eisblock XPX Aurora Edge CPU Cooler
Alphacool's Eisblock XPX Aurora Edge CPU water cooler offers the highest performance and impresses with its excellent quality. The patented ramp system ensures optimal water flow within the cooler, as the water is evenly pressed through the nozzle plate. 81 cooling fins are distributed on the CPU cooler base, covering an area of 34 x 32mm and thus do justice to the ever-growing CPU DIEs. The 15 digital aRGB LEDs offer many options for outstanding lighting of the CPU water cooler. The included mounting material makes the CPU cooler compatible with the common mainstream sockets from AMD and Intel.
Ice Cream Cup Aurora D5 Acetal/Glass 250ml & VPP Apex Pump
The Eisbecher Aurora expansion tank uses a real glass tube instead of the usual acrylic tubes. The embedded 5V digital RGB LED ring and the Lighttower water effect provide independent and elegant lighting. It is mounted using feet or directly on a free 120mm or 140mm fan slot. The Apex VPP is a powerful pump that is compatible with the most common D5/VPP tops and expansion tanks. The speed of the pump can be read via the 4-pin fan connector and controlled via a PWM signal. The Apex VPP is supplied with power via the SATA connector.
NexXxoS XT45 Full Copper 360mm Radiator V.2
All water-carrying parts and the cooling fins are made of pure copper. This means that the NexXxoS XT45 achieves the highest thermal conductivity of all radiators on the market and can easily dissipate extremely high levels of waste heat. The radiator has two IN or OUT connections with G1/4" threads in the pre-chamber area. On the opposite side there is a fill or vent port that can be used to fill and empty the water circuit.
Rise Aurora 120mm fan
The fan can be controlled from 0 to 2500 rpm via the 4-pin PWM connection. At 800 rpm, the fan is almost silent, but still offers a good air flow (118.9 m³/h) coupled with a high static pressure (3.17mm/H2O). In addition to a wide control range, the Rise fan also offers outstanding digital aRGB lighting. 20 digitally addressable 5V RGB LEDs are installed in the frame and hub, which illuminate the entire fan.
Ice tube 16/13mm PETG HardTube
The PETG HardTubes give the user the opportunity to give the water cooling a very special look. The tubes are very stable with a wall thickness of 3mm, but can still be processed and laid without much effort. The HardTubes are clear and therefore fit almost any water circuit. When shortening the tubes, make sure to smooth the cut edges with a fine file or a hose deburrer, as sharp edges can damage the O-rings of fittings.
Icicle 16/13mm G1/4" connections
All requirements that are placed on a connection are met here: high flow, shape, processing and color. The coating is firmly bonded to the substrate using special manufacturing processes. This increases the longevity of the color and prevents the coating from flaking off.
Thermal paste & coolant
The thermal paste included in the delivery is Alphacool's Subzero with a thermal conductivity of 16 W/mk. The electrically non-conductive thermal grease is particularly well suited for high contact pressures, but can still be processed perfectly due to the viscosity of 850,000 TF. Tec Protect 2 Clear in the 1 liter bottle is used as the coolant. With Tec Protect 2 Clear you get a ready-mix that already contains all the necessary additives and can be used straight from the bottle.
All cables (aRGB, PWM) and controllers required for the use and control of the pump, fan and aRGB lighting are included in the scope of delivery. The accessories package also includes important tools such as a spray bottle, deburring tool and pull saw. This means that you can start building the custom loop "out-of-the-box" straight away.
Intel: 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066
Technical data CPU cooler | |
Dimensions (L x W x H) | 70x70x32.5mm |
Material cooler | nickel-plated copper |
Housing material | Brass, acrylic |
Connections | 2xG1/4“ |
lighting | 3-pin 5V, 15 digital aRGB LEDs |
Maximum operating temperature | 60°C |
Pressure tested | 0.8 bars |
Technical data reservoir | |
Dimensions (L x W x H) | 77x77x242mm |
volume | 250ml |
Housing material | Acetal |
Material tube | Glass |
Material bridges | aluminum |
Connections | 1x G1/4“ IG IN / 4x G1/4“ IG OUT |
lighting | 5V digital addressable LEDs (0.3A) |
Technical data pump | |
Dimensions (L x W x H) | 65x65x41mm |
material | Plastic, aluminium, ceramic |
Connections | 4Pin PWM I SATA |
Control range | 2500 - 4500 RPM |
Operating voltage | 8-13V DC / 14W IP32 |
Starting voltage | 12V DC |
Maximum discharge head | 4.25m |
Maximum flow | 340L/h |
Technical data Radiator | |
Dimensions (L x W x H) | 391.5 x 124 x 45mm (+/- 3%) |
Material cooling fins, pre-chambers & cooling channels | copper |
Material thread | Brass |
Material outer casing | stainless steel |
Connections | 4x G1/4" IN/OUT & 1x fill/drain port G1/4" |
Possible fan size | 120mm |
Possible fan assignment | 3x one-sided / 6x double-sided |
Fin spacing | 12 |
Technical data fan | |
Dimensions (L x W x H) | 120x120x25mm |
Speed | 0-2500 rpm (+/-10%) |
Connections | 4-pin PWM |
Tension | 12V DC |
Rated current | 0.65A (0.72A max) |
Static pressure | 3.17mm/H2O |
Air flow | 118.9 m³/h |
volume | max. 31.5 dB(A) |
Speedometer signal | Yes |
Auto restart | Yes |
lighting | 3-pin 5V, 20 digital aRGB LEDs |
Technical data hose | |
Dimensions (external/internal) | 16/13mm |
material | PETG |
length | 4x 60cm |
Color | clear |
Technical data 16/13mm G1/4" connections | |
material | Brass |
Connections | 1x G1/4“ AG |
Color | black |
Technical data coolant | |
Ingredients | Osmosis water (93.8%), Glysofor L (4.2%), RHOBA KLA (2%) |
boiling point | 105°C |
freezing point | -10°C |
Packaging unit | 1L bottle |
Color | clear (not UV-active) |
Technical data thermal paste | |
Viscosity (mPa.s) | 3,000,000 |
Specific gravity (g/cm³) | 2.7 |
Thermal conductivity (w/mK) | 16 |
Temperature stability (degrees Celsius) | -50 ~ 200 |
Color | gray |
Radiatorgröße: | 360mm |
Vorbefüllt: | Nein |
Radiatordicke: | 39 - 49mm |
Radiatorabmessung: | 391,5 x 124 x 45mm |
Sockel: | AMD AM3(+), AMD AM4, AMD AM5, Intel 115x, Intel 2011(-3), Intel 2066, Intel LGA 1200, Intel LGA 1700 |
Schlauchabmessungen: | 16/10mm |
