Alphacool Core Geforce RTX 4090 Strix + TUF with Backplate
  • 13495
  • 4250197134958
  • 1,928 kg
€169.98 * €199.98 * (15% Saved)
€19.98*
ANK Alphacool HF quick release coupling set TPV - Eisbaer compatible - Black
€11.98*
€17.98*
€229.98*
Alphacool's Core product series is characterized by high quality, outstanding performance and... more
- Asus ROG Matrix GeForce RTX 4090 Platinum, ROG-MATRIX-RTX4090-P24G-GAMING, 24GB GDDR6X (90YV0ID7-M0NM00)
- Asus ROG Strix GeForce RTX 4090 OC, ROG-STRIX-RTX4090-O24G-GAMING, 24GB GDDR6X (90YV0ID0-M0NA00)
- Asus ROG Strix GeForce RTX 4090, ROG-STRIX-RTX4090-24G-GAMING, 24GB GDDR6X (90YV0ID1-M0NA00)
- Asus TUF Gaming GeForce RTX 4090 OC, TUF-RTX4090-O24G-Gaming, 24GB GDDR6X (90YV0IE0-M0NA00)
- Asus TUF Gaming GeForce RTX 4090, TUF-RTX4090-24G-GAMING, 24GB GDDR6X (90YV0IE1-M0NA00)
Technical data cooler
Dimensions (L x W x H)224,03 x 158,25 x 32,23mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom11,3mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs12
Colortransparent
Technical data backplate
Dimensions (L x W x H)224,03 x 135,25 x 5mm
Materialaluminium
Awards & Videos
Cooler type: Complete cooler
Material base plate: Copper;
Material Lid: Acrylic;
SLI compatible: Yes
Dimensions: 224,03 x 158,25 x 32,23mm
Connection: 4x G1/4"
Hardware model: RTX 4090;
€99.98 *
€33.98 *
Delivery date: in 7 - 8 days
20%
Content 2 Stück (€12.80 * / 1 Stück)
€25.59 * €31.98 *
Content 320 Zentimeter (€11.56 * / 100 Zentimeter)
€36.98 *
Content 10 Stück (€0.80 * / 1 Stück)
€21.98 *
€38.98 *
Alphacool VPP655 - PWM - Single Edition
€99.98 *
