Alphacool Eisblock Aurora Acryl RTX 4080 AMP - Trinity with backplate
- Article no.: WAK
- EAN: 4250197135498
- Weight: 1,605 kg
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Manli GeForce RTX 4080 Gallardo, 16GB GDDR6X (N68840800M35350/N68840800M35351)
- Zotac Gaming GeForce RTX 4080 AMP Extreme AIRO, 16GB GDDR6X (ZT-D40810B-10P)
- Zotac Gaming GeForce RTX 4080 Trinity OC, 16GB GDDR6X (ZT-D40810J-10P)
- Zotac Gaming GeForce RTX 4080 Trinity, 16GB GDDR6X (ZT-D40810D-10P)
- Zotac GAMING GeForce RTX 4080 SUPER AMP Extreme AIRO 16GB GDDR6X
Technical data cooler | |
L x W x H | 232,30 x 145 x 34,17mm |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 13 |
Technical data backplate | |
L x W x H | 232,30 x 120,50 x 6mm |
Material | aluminium |
Color | black |
SLI kompatibel: | Ja |
Kühlertyp: | Komplettkühler |
Anschluss: | 4x G1/4" |
Material Deckel: | Acryl |
Abmessungen: | 232,30 x 145 x 34,17mm |
Hinweis: | Kompatibel bis 16/13mm gerade, Kompatibel bis 19/13mm gewinkelt |
Hardware Modell: | RTX 4080 |
