Alphacool Eisblock Aurora Geforce RTX 4070 TI TUF Gaming with backplate
- Article no.: WAK
- EAN: 4250197137300
- Weight: 1,5 kg
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- Asus Dual GeForce RTX 4070 SUPER, DUAL-RTX4070S-12G, 12GB GDDR6X (90YV0K83-M0NA00)
- Asus TUF Gaming GeForce RTX 4070 SUPER, TUF-RTX4070S-12G-GAMING, 12GB GDDR6X
- Asus TUF Gaming GeForce RTX 4070 Ti OC, TUF-RTX4070TI-O12G-GAMING, 12GB GDDR6X (90YV0IJ0-M0NA00)
- Asus TUF Gaming GeForce RTX 4070 Ti, TUF-RTX4070TI-12G-GAMING, 12GB GDDR6X (90YV0IJ1-M0NA00)
- Asus TUF Gaming GeForce RTX 4070 Ti SUPER, TUF-RTX4070TIS-16G-GAMING, 16GB GDDR6X (90YV0KF1-M0NA00 )
Technical data cooler | |
Dimensions (L x W x H) | 231,00 x 142,50 x 36,27mm |
Pressure tested | 0,8 bar |
Threads | 4 x G1/4" |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 13 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 231,00 x 118,00 x 6,00mm |
Material | aluminium |
Color | black |
Kühlertyp: | Komplettkühler |
Anschluss: | 4x G1/4" |
Material Deckel: | Acryl |
Abmessungen: | 231,00 x 142,50 x 36,27mm |
Hardware Modell: | RTX 4070 Ti |
Liefertermin: in 2 - 3 Tagen
