Alphacool Core Hurrican 420mm XT45 HardTube water cooling Set
  • 11994
  • 4250197119948
  • 6,74 kg
€419.97 *
€18.98*
ANS Alphacool Eiszapfen 16mm HardTube screw-on nozzle G1/4 - Chrome Sixpack
€31.98*
SEN Alphacool Eisfluegel Aurora flow indicator "HighFlow" with speedometer signal
€34.98*
WZS Alphacool ES Big Inline Particle Filter 2x G1/4" IG PHT EOL
€29.98*
13009 Alphacool Subzero Thermal grease 20g
€33.97*
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Suprim with backplate PHT EOL
€119.98*
With the Core Hurrican HardTube water cooling kit, Alphacool provides all the components needed... more
With the Core Hurrican HardTube water cooling kit, Alphacool provides all the components needed to get started in the world of water cooling. The set is aimed not only at beginners, but also at enthusiasts. The selected components are optimally matched and come from Alphacool's DIY program. The choice of materials is still uncompromisingly based on copper or brass for all metals in order to guarantee performance-oriented CPU cooling.
Eisblock XPX Aurora Edge CPU Cooler
Alphacool's Eisblock XPX Aurora Edge CPU water cooler offers the highest performance and impresses with its outstanding quality. The patented ramp system ensures optimal water flow within the cooler as water is forced evenly through the jet plate. 81 cooling fins are distributed on the CPU cooler base, occupying an area of 34 x 32mm and thus accommodating the ever-growing CPU DIEs. The Aurora design in combination with the 15 addressable digital aRGB LEDs provides many options for outstanding CPU water cooler illumination. The included mounting hardware makes the CPU cooler compatible with popular mainstream sockets from AMD and Intel.
Eisbecher Aurora D5 250mm & VPP Apex Pump
The Alphacool Eisbecher Aurora glass reservoir uses a real glass tube rather than the usual plastic tube that Alphacool usually relies on. The embedded 5V digital RGB LED ring and the new design makes the reservoir look magnificent. Of course, the Lighttower water effect is used again. The mounting can be done via feet but also mounted on 120 or 140mm fan mounts or even directly to a radiator. The Apex VPP is a powerful pump that is compatible with the most popular D5/VPP tops and reservoirs. Via the 4-pin fan connector, the speed of the pump can be read and controlled via PWM signal. The Apex VPP is supplied with power via the SATA connector.
NexXxoS XT45 Full Copper 420mm Radiator V.2
All water-bearing parts and the cooling fins are made of pure copper. Thus, the NexXxoS XT45 achieves the highest thermal conductivity value of all radiators on the market and can easily dissipate extremely high waste heat. The radiator has two IN or OUT connections with G1/4" threads in the pre-chamber area. On the opposite side is a fill or vent port, which can be used to fill and drain the water loop.
Rise Aurora 140mm fans
The fans can be controlled from 0 to 2000 rpm via the 4-pin PWM connector. At 800 rpm, the fan is nearly silent, but still offers good airflow (154.1m3/h) coupled with high static pressure (2.20 mm/H2O). In addition to a wide control range, the Rise fan also offers superior digital aRGB lighting. The frame and hub feature 24 digitally addressable 5V RGB LEDs that illuminate the entire fan.
Eisrohr 16/13mm PETG HardTube
The Alphacool Eisrohr PETG HardTube givse the user the possibility to create a very special look. With a wall thickness of 3 mm, the tubes are very strong, but can still be bent without great effort and they are easy to fit. The HardTubes are clear and will look great in almost every water cooling loop. When cutting the tubes, make sure to chamfer the edges with fine file or a hose deburrer, as sharp edges can damage the O-rings of fittings.
Eiszapfen 16/13mm G1/4" Connections
Thermal Paste & Coolant
All cables (aRGB, PWM) and controllers needed to use & control the pump, fan and aRGB lighting are included. The accessory package also includes important tools like filling bottle, deburrer and pit saw. Thus, the construction of the custom loop can be started "out-of-the-box" immediately.
Intel: 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066 / 1851
Technical data CPU cooler
Dimensions (L x W x H)70 x 70 x 32,5mm
Material coolernickel-plated copper
Material housingbrass, acrylic
Threads2 x G1/4“
Illumination3-Pin 5V, 15 digital aRGB LEDs
Max working temperature60°C
Pressure tested0,8 Bar
Technical data reservoir
Dimensions (L x W x H)77 x 77 x 242mm
Capacity250ml
Material housingAcetal
Material tubeGlass
Material framing barAluminium
Threads1x G1/4“ IT IN | 4x G1/4“ IT OUT
Illumination5V digital addressable LED‘s (0,3A)
Technical data pump
Dimensions (L x W x H)65 x 65 x 41mm
Materialsynthetic material, aluminium, ceramics
Threads4Pin PWM I SATA
Starting voltage12V DC
Maximum pumping head4,25m
Maximum flow rate340L/h
Technical data radiator
Dimensions (L x W x H)455,5 x 144 x 45mm (+/- 3%)
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4"
Possible fan size140mm
Possible fan assembly3x one-sided / 6x both-sided
Fin density12
Technical data fan
Dimensions (L x W x H)140 x 140 x 25mm
Speed0-2000 rpm (+/-10%)
Threads4-Pin PWM
Voltage12V DC
Current consumption6,6 Watt (max)
Static pressure2,20 mm/H2O
Max. air flow154,1 m³/h
Noisemax. 38,4 dB(A)
Speedometer signalyes
Auto-Restartyes
Illumination3-Pin 5V, 24 digital aRGB LEDs, 3.5W
Technical data tube
Dimensions (outer/inner)16/13mm
MaterialPETG
Length4x 60cm
Colorclear
Technical data 16/13mm G1/4" fittings
Materialbrass
Threads1x G1/4" OT
Technical data coolant
Ingredientsosmose water(93,8%), glysofor L (4,2%), RHOBA KLA (2%)
Boiling point105°C
Freezing point-10°C
Packaging unit1L bottle
Colorclear (not UV-active)
Technical thermal grease
Viscosity (mPa. s)3.000.000
Specific Gravity (g/cm³)2,7
Thermal Conductivity (w/m-K)16
Temperature Stability (Degree Celcius)-50 ~ 200
Colorgray
Awards & Videos
Radiator dimensions: 455,5 x 144 x 45mm
Radiator thickness: 39 - 49mm
Radiator size: 420mm
Hose dimensions: 16/10mm
Base: AMD AM3(+), AMD AM4, AMD AM5, Intel 115x, Intel 2011(-3), Intel 2066, Intel LGA 1200, Intel LGA 1700, Intel LGA 1851
Prefilled: No
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
€34.98 *
ANS Alphacool HT 16mm HardTube Anschraubtülle G1/4 - gerändelt - Deep Black Sixpack
Content 6 Stück (€4.50 * / 1 Stück)
€26.98 *
WAR Alphacool D-RAM Cooler X4 Universal - Acetal Black Nickel
€54.98 *
Alphacool HF screw plug G1/4 - Deep Black
€1.68 *
Liefertermin: in 7 - 8 Wochen
RAD Alphacool NexXxoS XT45 Full Copper 420mm Radiator
€99.98 *
RAD Alphacool NexXxoS XT45 Full Copper 360mm Radiator
WAK Alphacool Core RX 9070 XT Taichi mit Backplate
Alphacool Core RX 9070 XT Taichi with backplate
€199.98 *
WAK Alphacool Core Geforce RTX 5090 Reference mit Backplate
Alphacool Core Geforce RTX 5090 Reference with backplate
€199.98 *
Liefertermin: in 5 - 6 Tagen
25%
WAK Alphacool Eisblock Aurora RX 7900XTX Reference mit Backplate PHT EOL
Alphacool Eisblock Aurora RX 7900XTX Reference with backplate
€119.98 * €159.98 *
15%
WAK Alphacool Core Geforce RTX 4090 Strix + TUF mit Backplate PHT EOL
Alphacool Core Geforce RTX 4090 Strix + TUF with Backplate
€169.98 * €199.98 *
KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm
Alphacool Mini USB to Mainboard USB 5-Pin 40cm
Content 40 Zentimeter (€7.45 * / 100 Zentimeter)
€2.98 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 120x20x0,5mm
Alphacool Core thermal pad Soft 6.2W/mk 120x20x0.5mm
Content 24 cm² (€0.25 * / 1 cm²)
€5.99 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x1mm
Content 16 cm² (€0.31 * / 1 cm²)
€4.97 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Content 6 Stück (€2.16 * / 1 Stück)
