Alphacool Eisblock Aurora Geforce RTX 4070 TI ROG Strix with Backplate
  • 13749
  • 4250197137492
  • 1,752 kg
€99.98 *
€6.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
18662 Alphacool EPDM Tube 13/10 - Black 1m (3,28ft) Retailbox
€9.98*
SZ Alphacool hose cutter aluminum 3-19mm
€18.98*
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics... more
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
- Asus ROG Strix GeForce RTX 4070 Ti OC, ROG-STRIX-RTX4070TI-O12G-GAMING (90YV0II0-M0NA00)
- Asus ROG Strix GeForce RTX 4070 Ti, ROG-STRIX-RTX4070TI-12G-GAMING (90YV0II1-M0NA00)
- Asus ROG Strix GeForce RTX 4070 Ti SUPER OC, ROG-STRIX-RTX4070TIS-O16G-GAMING, 16GB GDDR6X (90YV0KG0-M0NA00)
- Asus ROG Strix GeForce RTX 4070 Ti SUPER, ROG-STRIX-RTX4070TIS-16G-GAMING, 16GB GDDR6X (90YV0KG1-M0NA00)
Dimensions (L x W x H)240 x 156,90 x 34,70mm
Material cooler topacrylic
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Number of digital aRGB LEDs14
Power digital aRGB LEDs5V
Pressure tested0,8 bar
Max working temperature60°C
Technical data backplate
Dimensions (L x W x H)240,00 x 132,40 x 6mm
Materialaluminium
Warranty: 2 years
Awards & Videos
€5.99 *
Delivery date: in 6 - 7 days
€3.78 *
Delivery date: in 7 - 8 weeks
Delivery date: in 11 - 12 weeks
€23.98 *
S16 Alphacool EPDM Tube 16/10 - Black 1m (3,28ft) Retailbox
20%
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
Alphacool Apex PCI-e 4.0 Riser cable - 20cm
Content 20 Zentimeter (€299.90 * / 100 Zentimeter)
€59.98 * €74.98 *
€3.47 *
€2.78 *
€2.48 *
