Alphacool Eisblock Aurora Acryl RTX 4080 Suprim with Backplate
- Article no.: 13527
- EAN: 4250197135276
- Weight: 1,919 kg
Erhalte 20% Rabatt auf ausgewählte Produkte. Der gewährte Rabatt ist im Warenkob sichtbar.
*1The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- MSI GeForce RTX 4080 16GB Suprim X, 16GB GDDR6X (V511-004R)
- MSI GeForce RTX 4080 Gaming X Trio 16GB, 16GB GDDR6X (V511-005R)
- MSI GeForce RTX 4080 SUPER 16G GAMING TRIO
- MSI GeForce RTX 4080 SUPER 16G GAMING X TRIO
- MSI GeForce RTX 4080 SUPER 16G SUPRIM
- MSI GeForce RTX 4080 SUPER 16G SUPRIM X (V511-248R)
| Technical data cooler | |
| Dimensions (L x W x H) | 266,66 x 162,43 x 33,63mm |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Illumination | 11x digital aRGB LEDs |
| Color | transparent |
| Dimensions (L x W x H) | 266,66 x 137,93 x 6mm |
| Material | Aluminum |
| Color | black |
