Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Founders Edition with Backplate
  • 13456
  • 4250197134569
  • 1,889 kg
€49.98 * €159.98 * (68.76% Saved)
ROH Alphacool Eisbaer TPV Extension Set 90° (hose and connections)
€19.98*
11999 Alphacool Eisbaer Aurora HPE Edition 360 CPU AIO
€188.98*
€6.98*
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics... more
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Nvidia GeForce RTX 4090 Founders Edition, 24GB GDDR6X (900-1G136-2530-000)
Technical data cooler
L x W x H205.42 x 147.04 x 34.62 mm
Material cooler topacrylic
Max working temperature60 °C
Pressure tested0.8 bar
Threads4 x G 1/4
Thickness cooling fins0.4 mm
Distance cooling fins0.4 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5 V
Number of digital aRGB LEDs12
Technical data backplate
L x W x H205.42 x 122.89 x 6 mm
Materialaluminium
€4.38 *
S16 Alphacool Schlauch AlphaTube TPV 16/10 - Black Matte 50m Rolle
Alphacool Tubing AlphaTube TPV 16/10 - Black Matte 50m Roll
Content 5000 Zentimeter (€5.70 * / 100 Zentimeter)
€284.98 *
Alphacool Eiszapfen 14mm HardTube screw-on nozzle G1/4 - Deep Black Sixpack
€34.98 *
€6.99 *
€38.98 *
€20.98 *
