Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Founders Edition with Backplate
- Article no.: 13456
- EAN: 4250197134569
- Weight: 1,889 kg
The next generation - The Alphacool Eisblock Aurora water cooler for Geforce RTX 4XXX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
Thermal paste & thermal pads
- Nvidia GeForce RTX 4090 Founders Edition, 24GB GDDR6X (900-1G136-2530-000)
| Technical data cooler | |
| L x W x H | 205.42 x 147.04 x 34.62 mm |
| Pressure tested | 0.8 bar |
| Threads | 4 x G 1/4 |
| Thickness cooling fins | 0.4 mm |
| Distance cooling fins | 0.4 mm |
| Power digital aRGB LEDs | 5 V |
| Number of digital aRGB LEDs | 12 |
| L x W x H | 205.42 x 122.89 x 6 mm |
| Material | aluminium |
| Color | black |
