Alphacool GPU Terminal - Acetal
  • 12965
  • 4250197129657
  • 0,03 kg
€20.98 *
17228 Alphacool Eiszapfen 13/10mm compression fitting G1/4 - deep black sixpack
€35.98*
€35.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Chrome
€8.98*
ANS Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
This spare part is compatible with various Alphacool GPU coolers. It replaces the original... more
This spare part is compatible with various Alphacool GPU coolers. It replaces the original component without adding any extra features or performance improvements. A detailed list of compatible and incompatible products can be found below.
All Alphacool Eisblock Aurora coolers
All Alphacool Core coolers for the RTX 5XXX and AMD RX 9XXX series
The terminal is not compatible with the Alphacool Core coolers of the RTX 4XXX and RX 7XXX series.
Note: Please follow the manual for the correct flow direction of the water.
Warranty: 2 years
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
WAGZ Alphacool GPU Terminal flat straight - Acetal
€1.78 *
€2.98 *
€5.78 *
€1.48 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
WAC Alphacool Core 1 Silver
