Phobya Y-Kabel 3Pin Molex auf 4x 3Pin Molex - Schwarz 60cm
  • LK
  • 4049469077976
  • 0,025 kg
€5.68 *
Content: 60 Zentimeter (€9.47 * / 100 Zentimeter)
For connection of 4 fans with 3-Pin connectors to a 3-Pin connector e.g. on the Mainboard.... more
For connection of 4 fans with 3-Pin connectors to a 3-Pin connector e.g. on the Mainboard. Please note that the speed monitoring of only one connected fan is possible with this adaptor cable. A white sticker on one of the cables shows which connector can be monitored.
Sleeving:
This cable is not only practical, it is also optically appealing, The surrounding mesh, also called sleeve, which is surrounding the cable itself offers the advantages that every Pro-modder is looking for: A completely unique look, even of the cables in the system! Special attention was paid to the combination of cable connectors, sleeve and heatshrink which were used to ensure great design and a unique as well as elegant look.
The idea behind these cables:
Technical specifications:
Connectors: 3-Pin to 4x 3-Pin Y-cable
Colour: Black sleeve, black connectors and black heatshrink
Dimensions: 30cm length each
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 3-Pin Molex to 64 3-Pin Molex 30cm - Black
Please note: If connecting multiple fans to one fan socket by using these adapters please ensure that the source is specified to supply enough current to safely supply all fans together. Too high loads may result in damages to the system.
This product has been reviewed for you:
Aquainfos
Tech-Review
Bauform: Y-Kabel
Hersteller: Phobya
Sleeving: schwarz
1. Seite: 1x 3Pin
2. Seite: 4x 3Pin
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
LK Phobya Adapter 3Pin (12V) auf 3Pin (7V) - Schwarz 20cm
Content 20 Zentimeter (€17.40 * / 100 Zentimeter)
€3.48 *
Hint!
LK Phobya 4Pin PWM Verlängerung 60cm EOL
Content 60 Zentimeter (€6.63 * / 100 Zentimeter)
€3.98 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
WAC Alphacool Core 1 White
€109.98 *
WAC Alphacool Core 1 Silver
€99.98 *
€99.98 *
Liefertermin: in 7 - 8 Tagen
PSU Alphacool Core 60W PSU Extern
€34.97 *
KAB Alphacool Apex PCI-e 4.0 Riser Kabel - 20cm
Alphacool Apex PCI-e 4.0 Riser cable - 20cm
Content 20 Zentimeter (€374.90 * / 100 Zentimeter)
€74.98 *
RAK Alphacool ES Orbiter Filling Station
€399.98 *
WAC Alphacool Core XP³ Acetal
€34.97 * €39.98 *
KOI Alphacool Core Ocean T38 AIO 280mm
KOI Alphacool Core Ocean T38 AIO 240mm
€74.98 *
RAD Alphacool NexXxoS HPE-45 Full Copper 480mm Radiator
€141.98 *
KOI Alphacool Core Storm 360mm XT45 Wasserkühlungs Set
Alphacool Core Storm 360mm XT45 water cooling Set
€359.98 * €379.98 *
€2.98 *
PUM Alphacool Eisstation DC80 - AIO Power Unit
€69.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 360mm Radiator
€104.98 *
Liefertermin: in 8 - 9 Wochen
KOI Alphacool Eisbaer Pro Aurora 240 CPU AIO
€179.98 *
Alphacool tubing AlphaTube HF 10/8 (5/16"ID) - Ultra Clear 3m (9,8ft) Retailbox
Content 300 Zentimeter (€2.66 * / 100 Zentimeter)
RAD Alphacool NexXxoS XT45 Full Copper 1260mm SuperNova Radiator
€199.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon 5700 XT Nitro+ EOL
€81.41 * €129.97 *
PUM Alphacool Eisball Digital RGB - Acryl (inkl. Eispumpe VPP755 V.3)
Alphacool Eisball Digital RGB - Acryl (incl. Eispumpe VPP755 V.3)
€114.98 * €129.98 *
RAD Alphacool NexXxoS ST30 Full Copper 360mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 360mm radiator V.2
€79.98 * €92.97 *
RAD Alphacool NexXxoS ST30 Full Copper 120mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 120mm radiator V.2
€44.98 * €52.98 *
WAC Alphacool Eisblock XPX CPU - Satin Clear Version
Alphacool Eisblock XPX CPU - satin clear version
€39.98 * €59.98 *
RAD Alphacool NexXxoS ST30 Full Copper X-Flow 480mm Radiator
Alphacool NexXxoS ST30 Full Copper X-Flow 480mm radiator
€94.99 * €109.98 *
AGB Alphacool Eisbecher Lite 150mm Acetal Ausgleichsbehälter EOL
Alphacool Eisbecher Lite 150mm Acetal reservoir
€26.99 * €29.98 *
Alphacool Eiszapfen 13/10mm compression fitting G1/4 - chrome sixpack
€33.98 *
LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm
Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
Content 60 Zentimeter (€11.62 * / 100 Zentimeter)
€6.97 *
€1.88 *
Hint!
LZ Phobya 4Pin PWM auf 8x 4Pin Splitter EOL
€8.48 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear
