Phobya 4Pin PWM to 3x 4Pin PWM extension - Black 40cm
- Article no.: LK
- EAN: 4049469125417
- Weight: 0,019 kg
This cable is intended to connect several fans to a PWM slot, e.g. on the mainboard, in order to control and read them.
Important: In order to read and control the fans correctly, they must all be from the same series. Different fans can also be operated, but the speed values will not be displayed correctly.
Please note: Multiple fans on one slot could exceed the maximum permissible voltage and thus cause damage to the control unit!
Sleeve:
Sets:
Technical details:
Length: 40 cm - 20cm, 10cm and 10cm
Color: black sleeve
Connection: 1x 4Pin plug (male) to 3x 4Pin socket (female)
1x Phobya 4Pin PWM to 3x 4Pin PWM extension 40cm - Black
Note: Please note the difference between a 4 pin power connector (Molex) and a 4 pin fan connector (PWM).
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
2. Seite: | 3x 4Pin PWM |
